What Is A Radiation? (Heat Transfer)
In summary, the conversation discusses radiation and its different forms, specifically focusing on infrared (IR) radiation. The speakers also mention the use of animation to help understand the concept and suggest using Google for further information.
mymachine
42
Could anyone please illustrate me about radiation by an illustration?
If don't mind, animation could be great.
The IR part of sunlight(mostly) carries heat. That is radiation.
What is IR?
IR is infra-red
Actually, ALL "light", visible to the human eye or not, is radiation. Radio waves are radiation. The entire electromagnetic spectrum is radiation.
This is such a basic concept that you should just poke around with Google.
Next question, what is infra red?
You REALLY need to learn how to use Google.
Prefer to ask it here.
Then you should check this out:
https://www.physicsforums.com/blog.php?b=3588
FAQ: What Is A Radiation? (Heat Transfer)
What is radiation and how does it differ from conduction and convection?
Radiation is a type of heat transfer that occurs through electromagnetic waves. Unlike conduction and convection, it does not require a medium to transfer heat. Radiation can occur through a vacuum, such as in space, while conduction and convection require a physical medium, such as a solid or fluid, to transfer heat.
What are the different types of radiation?
There are three main types of radiation: infrared radiation, visible light, and ultraviolet radiation. Infrared radiation has longer wavelengths and is responsible for heat transfer in everyday objects, while visible light has shorter wavelengths and is responsible for the colors we see. Ultraviolet radiation has even shorter wavelengths and can be harmful to living organisms.
How does radiation affect the temperature of an object?
Radiation can both increase and decrease the temperature of an object, depending on the source and intensity of the radiation. For example, the sun's radiation can increase the temperature of objects on Earth, while objects with a higher temperature can emit radiation and cool down.
What is the role of radiation in the Earth's heat balance?
Radiation plays a crucial role in the Earth's heat balance, also known as the greenhouse effect. The Earth's atmosphere acts like a blanket, trapping some of the sun's radiation and preventing it from escaping into space. This helps to maintain a relatively stable temperature on Earth and supports life.
How is radiation measured and quantified?
Radiation can be measured and quantified using different units, such as watts per square meter (W/m²) or joules per square meter (J/m²). These units measure the amount of energy transferred through radiation over a specific area. Other measures, such as the Stefan-Boltzmann Law, can be used to calculate the rate of radiation emitted by an object based on its temperature.
