MHB What is a simpler method to find the perimeter of triangle AMN?
  • Thread starter Thread starter veronica1999
    Perimeter Triangle
To find the perimeter of triangle AMN, the area of triangle ABC is calculated using Heron's formula, yielding an area of 135. The radius of the incircle is determined to be 5, leading to a height of 9 for triangle ABC. The side lengths of triangle AMN are derived using the ratio 9:5 based on the incenter's position. The calculations suggest that the perimeter of triangle AMN is 30. A simpler method is sought, focusing on the incenter and angle bisector properties for more straightforward calculations.
veronica1999
Triangle ABC has side-lengths AB=12,BC=24,and AC=18. The line
through the incenter of ABC parallel to BC intersects AB at M and AC at
N. What is the perimeter of triangle AMN?
(A)27 (B)30 (C)33 (D)36 (E)42
My friend is saying my solution is too messy and there was no need for the heron's formula. (without telling me how he solved it
Can someone show me a simpler way to solve this?
I used the herons formula to get the area of ABC.
Area is 135.
Then i found the radius of the incircle.
6r+9r+12r = 135
r= 5
The height of the triangle ABC is 45/5 ,
so using the rate of 45/5 : 25/5 which is 9:5
I got the lengths of all the other sides.
12: X = 9:5
60/9
24: X = 9:5
120/9
18 : X = 9:5
90/9
270/9 = 30
Mathematics news on Phys.org
Area is 135.
6r+9r+12r = 135
r= 5
12: X = 9:5
60/9
24: X = 9:5
120/9
18 : X = 9:5
90/9
270/9 = 30
Let $I$ be the incenter.
Let $AI$ meet $BC$ at $D$.
So $\frac{AB}{BD}=\frac{AC}{CD}$.
This gives the exact lengths of $BD$ and $DC$.
Note that $CI$ is the angle bisector of angle $ ACD$.
Again $\frac{AI}{ID}=\frac{AC}{CD}$.
So now you know the value of $\frac{AI}{ID}$.
Note that using similarity in $\Delta ADC$ we have $\frac{AN}{NC}=\frac{AI}{ID}$.
Can you finish?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
