In summary, the gradient of a curve or surface at a particular point is equal to the gradient of the tangent to that curve or surface at the same point. This applies to both two-dimensional and n-dimensional spaces, where the tangent is defined as the derivative of the curve or surface at that point. This concept can also be expressed in terms of parameters, where the tangent is defined as the ratio of the difference between the point and the parameter to the derivative of the parameter. This concept is used in various fields, such as physics and mathematics, to understand and analyze curves and surfaces.
10,213
Definition/Summary
The tangent to a curve in a plane at a particular point has the same Gradient as the curve has at that point.
More generally, the (n-1)-dimensional tangent hyperplane to an (n-1)-dimensional surface in n-dimensional space at a particular point has the same Gradient as the surface has at that point.
So if [itex]A\,=\,(a_1,a_2,\cdots a_n)[/itex] is a point on a surface defined by the equation [itex]F(x_1,x_2,\cdots x_n) = 0[/itex], then the tangent hyperplane to the curve through [itex]A[/itex] is [itex]\frac{\partial F}{\partial x_1}\arrowvert_A(x_1 – a_1)\,+\,\frac{\partial F}{\partial x_2}\arrowvert_A(x_2 – a_2)\,+\,\cdots\,\frac{\partial F}{\partial x_2}\arrowvert_A(x_n – a_n)\,=\,0[/itex]
If a curve in n dimensions is defined using a parameter t as [itex]A(t)\,=\,(a_1(t),a_2(t),\cdots a_n(t))[/itex] , then its tangent is:
[itex](x_1 – a_1) / \frac{da_1}{dt}\,=\,(x_2 – a_2) / \frac{da_2}{dt}\,=\,\cdots\,=\,(x_n – a_n) / \frac{da_n}{dt}[/itex]
Equations
For...
Continue reading...
Mathematics news on Phys.org
Related to What is a Tangent Line? A 5 Minute Introduction
A tangent line is a line that touches a curve at exactly one point, without crossing over or intersecting with the curve at any other point.
How is a Tangent Line different from a Secant Line?
A secant line intersects a curve at two points, while a tangent line only touches the curve at one point.
What is the purpose of a Tangent Line?
The tangent line helps us understand the behavior of a curve at a specific point. It can also be used to approximate the slope of a curve at that point.
How is the slope of a Tangent Line calculated?
The slope of a tangent line is calculated using the derivative of the curve at the point where the tangent line touches the curve.
What are the real-life applications of Tangent Lines?
Tangent lines are used in fields such as physics, engineering, and economics to understand the rate of change of a system or to approximate the behavior of a complex curve. They are also used in navigation to calculate the direction of travel at a specific point.
