What is $a_{1996}$ in this series?
  • MHB
  • Thread starter anemone
In summary, a series in mathematics is a sum of terms that represents a mathematical concept or a set of numbers with a specific pattern. To find the value of a term in a series, a formula or pattern can be used. $a_{1996}$ represents the 1996th term in a series and can be negative or an integer, depending on the pattern or formula used.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Let \(\displaystyle \prod_{n=1}^{1996} (1+nx^{3n})=1+a_1x^{k_1}+a_2x^{k_2}+\cdots+a_mx^{k_m}\) where $a_1,\,a_2,\,\cdots a_m$ are non-zero and $k_1<k_2<\cdots<k_m$.
Find $a_{1996}$.
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
No one answered last week's POTW.(Sadface) You can find the suggested solution below.
Note that $k_i$ is the number obtained by writing $i$ in base 2 and reading the result as a number in base 3, and $a_i$ is the sum of the exponents of the powers of 3 used. In particular,
$1996=2^{10}+2^9+2^8++2^7+2^6+2^3+2^2$
So $a_{1996}=10+9+8+7+6+3+2=45$
FAQ: What is $a_{1996}$ in this series?
What is the meaning of $a_{1996}$ in this series?
$a_{1996}$ refers to the 1996th term in the series. It is a variable used to represent a specific value in a mathematical or scientific sequence.
How do you calculate $a_{1996}$ in this series?
To calculate $a_{1996}$, you would need to know the formula or pattern for the series. Then, you can plug in 1996 for the variable and solve for the value of $a_{1996}$.
Can you provide an example of finding $a_{1996}$ in a series?
Sure, let's say the series is 3, 6, 9, 12, 15... In this case, the formula would be an = 3n, where n represents the term number. To find $a_{1996}$, we would plug in 1996 for n, giving us a1996 = 3(1996) = 5988. Therefore, $a_{1996}$ in this series would be 5988.
Why is $a_{1996}$ important in this series?
$a_{1996}$ is important because it represents a specific value in the series. It allows us to identify and analyze the 1996th term, which may provide insights into the overall pattern or behavior of the series.
Is there a way to find $a_{1996}$ without knowing the formula for the series?
No, in order to find $a_{1996}$, you would need to know the formula or pattern for the series. Without this information, it would not be possible to accurately calculate the value of $a_{1996}$.
