What is alpha-complementation?
In summary: The C terminal peptide is responsible for the active site and the N terminal peptide is responsible for the substrate binding site.
TytoAlba95
132
I am completely stumped by this question. I can't understand what is meant by complementation.
Here's an excerpt from Primrose:
'The activity of the enzyme b-galactosidase is easily monitored by including in the growth medium the chromogenic substrate 5-bromo- 4-chloro-3-indolyl-b-D-galactoside (Xgal). This compound is colorless but on cleavage releases a blue indolyl derivative. On solid medium, colonies that are expressing active b-galactosidase are blue in color while those without the activity are white in color. This is often referred to as blue/white screening. Since Xgal is not an inducer of b-galactosidase, the non-substrate (gratuitous) inducer isopropyl-b-D-thiogalactoside (IPTG) is also added to the medium.
The phenomenon of a-complementation of b-galactosidase is widely used in molecular genetics. The starting-point for a complementation is the M15 mutant of E. coli. This has a deletion of residues 11–41 in the lacZ gene and shows no b-galactosidase activity. Enzyme activity can be restored to the mutant enzyme in vitro by adding a cyanogen bromide peptide derived from amino acid residues 3–92 (Langley et al. 1975, Langley & Zabin 1976). Complementation can also be shown in vivo. If a plasmid carrying the N-terminal fragment of the lacZ gene encompassing the missing region is introduced into the M15 mutant, then b-galactosidase is produced (how?), as demonstrated by the production of a blue color on medium containing Xgal.
In practice, the plasmid usually carries the lacI gene and the first 146 codons of the lacZ gene, because in the early days of genetic engineering this was a convenient fragment of DNA to manipulate. Since wild-type b-galactosidase has 1021 amino acids, it is encoded by a gene 3.1 kb in length. While a gene of this length is easily manipulated in vitro, there are practical disadvantages to using the whole gene. As will be seen later, it is preferable to keep cloning vectors and their inserts as small as possible. The phenomenon of a-complementation allows genetic engineers to take advantage of the lac system without having to have the entire Z gene on the vector.'
Biology news on Phys.org
I found the answer!
α complementation is a phenomenon where two inactive peptides(originally components of a single polypeptide); one C terminal and another N terminal peptides, associate to form a functional enzyme.
Likes BillTre
Related to What is alpha-complementation?
1. What is alpha-complementation?
Alpha-complementation is a process in which a missing or non-functioning gene is complemented by a functional copy of the same gene. This results in the restoration of the gene's normal function within the cell.
2. How does alpha-complementation work?
Alpha-complementation works by introducing a functional copy of a gene into a cell that has a non-functional version of the same gene. The new copy of the gene provides the necessary instructions for the cell to produce the missing protein and restore its normal function.
3. What types of genes can be alpha-complemented?
Alpha-complementation can be applied to any type of gene, as long as there is a functional copy of the gene available. This process is commonly used in genetic studies and biotechnology to introduce new genes into cells or organisms.
4. What are the applications of alpha-complementation?
Alpha-complementation has a wide range of applications in genetics, biotechnology, and medicine. It can be used to study gene function, create genetically modified organisms, and produce therapeutic proteins for treating diseases.
5. Are there any limitations to alpha-complementation?
One limitation of alpha-complementation is that it requires a functional copy of the gene to be available. If there is no functional copy of the gene, this process cannot be used. Additionally, the introduced gene may not always be expressed at the desired level, which can affect the success of alpha-complementation.
