What is an arcsec and how do I convert it into AU or m?
  • Stargazing
  • Thread starter marc873a
In summary, an arcsecond (arcsec) is a unit of angular measurement equal to 1/3600 of a degree. To convert arcseconds into astronomical units (AU) or meters (m), one can use the small angle approximation, where the distance in AU can be calculated by multiplying the distance in parsecs by the angular measurement in arcseconds and dividing by 206265. For conversions to meters, this involves converting AU to meters (1 AU ≈ 1.496 x 10^11 m) after calculating the distance in AU.
marc873a
I'm trying to calculate a few different things about sgr a* using the stars that orbit it. I have found this table which includes all the stars that orbit:
https://en.wikipedia.org/wiki/Sagittarius_A*_cluster
My problem is, that the semi-major axis is measured in arcsec, and I need it in AU or m. What is arcsec and how do I convert it into the other units?
Thanks in advance :)
Astronomy news on Phys.org
An arcsec is a measure of an angle equal to 1/60 of an arcminute, which in turn is 1/60 of a degree.
Okay, thanks. How do I convert that into a distance unit like AU or m?
You need to know how far you are from the separated objects, in AU or m.
Then you can use trigonometry, or the approximation of the sin(small angle) in radians.
They have different physical dimension, so generally you don’t.
If you want to convert to an actual semimajor axis you need not only the distance, but also the angle the orbital plane makes with the direction from the Earth.
Likes Vanadium 50
Okay so the distance from earth to sgr a* is 26670 ly or about 2.523 * 10^20 m away. According to the wiki site I linked, the star, S2, has a semi-major axis of 0.1251 arcsec.
What would the distance from S2 to sgr a* be?
Likes Vanadium 50
Not in this case, from the look of it. The value provided for a appears to be the actual inferred orbital element, and not an observable.
I suspect it's given in arcseconds only because the scale of the orbits is sensitive to the uncertainty in the distance to the central black hole.
What you can do is take the angular size for a from the table, treat it as if it were perpendicular to your line of sight, and use the small-angle approximation (look at the 'geometric' section): ##a=\theta d##, where a is the size of the semi-major axis in AUs, d is the distance to the black hole in AUs, and ##\theta## is the value for a in radians. You need to convert arcseconds to radians (multiply by ##\frac{\pi}{648000}##).
Or, you can just go to the column labelled q, and use eccentricity to get the semi-major axis: ##q=a(1-e)##
This column already assumes some particular value(s) for the distance to the black hole.
Thank you very much :)
FAQ: What is an arcsec and how do I convert it into AU or m?
What is an arcsec?
An arcsec, or arcsecond, is a unit of angular measurement equal to 1/3600th of a degree. It is commonly used in astronomy to describe the apparent sizes of objects in the sky or the precision of measurements.
How do I convert an arcsec into astronomical units (AU)?
An arcsecond itself is a measure of angle, not distance. To convert an angular measurement in arcseconds to a physical distance such as astronomical units (AU), you need additional information, such as the actual distance to the object being measured. The formula involves using the small-angle approximation: distance (AU) = (actual size of the object / angular size in radians) * (1 AU). Note that 1 arcsec = 1/206265 radians approximately.
How do I convert an arcsec into meters?
Similar to converting to AU, converting an arcsecond to meters requires knowing the actual distance to the object. Using the small-angle approximation: distance (meters) = (actual size of the object / angular size in radians). To find the angular size in radians, 1 arcsec = 1/206265 radians approximately.
What is the relationship between arcseconds and parsecs?
A parsec is defined as the distance at which one astronomical unit subtends an angle of one arcsecond. Therefore, 1 parsec = 206,265 AU. This relationship is fundamental in astronomical distance measurements and helps in converting angular measurements to distances when the object's parallax angle is known.
Why is the arcsec a useful unit in astronomy?
The arcsec is a useful unit in astronomy because it allows for precise measurements of very small angles, which is essential when observing distant celestial objects. Given the vast distances in space, even tiny angular measurements can correspond to significant physical distances, making the arcsec a practical unit for astronomers.
