What is an electrostatic/Coulomb barrier? How is it created?
In summary, for nuclear fusion to occur, particles must overcome the electrostatic field which is a force that surrounds charged particles and attracts particles with opposite charges while repelling particles with the same charge. This force is similar to the gravitational field but always attracts. This force is stronger between individual particles like protons compared to magnets and depends on the amount of energy the particles have. In order for nuclear fusion to happen, the particles must be pushed together close enough to overcome the repulsive electrostatic force and allow the strong interaction to fuse them together.
smartypants123
I learned that for nuclear fusion to take place, particles must overcome the electrostatic field but what exactly is it? And how is it created/formed?
It's pretty simple stuff. Unlike charges attract but like charges repel. The particles that we're fusing (atomic nuclei) are positively charged so they naturally repel one another; to fuse them we have to force them together ("push them through the Coulomb barrier").
The electrostatic field is the field that surrounds a charged particle and attracts particles with one charge and repels particles with the other charge. It's pretty much analogous to the gravitational field that surrounds the Earth and pulls things towards the earth; the only big difference is that the gravitational field happens to always attract.
This is an illustration of what Nugatory was describing:
Zz.
Likes Imager
Well that kinda gives me a new question: I'm assuming this electromagnetic field applies to magnets as well, so why is it that I can touch two magnets that repel each other and break the electrostatic field but for the nuclear fusion particles it wouldn't be so easy? Why is the electrostatic field stronger with those individual particles? Does it depend on the amount of energy they have?
If you take two protons there are two different forces between them: one is the long range repelling electrostatic force [every charged particle, like a proton, produces an electric force onto every other charged particles], the other is the very short range "strong interaction" that binds the two particles together. So you need to push the two protons close enough (overcoming the repulsive force) in order for the strong interaction to fuse them together.
Related to What is an electrostatic/Coulomb barrier? How is it created?
An electrostatic/Coulomb barrier is a force field that exists between two charged particles. It is created by the electrostatic force, which is the attraction or repulsion between two charged objects based on their magnitude and distance.
How is it created?
The electrostatic barrier is created by the interaction between two charged particles. When two particles with opposite charges are brought close together, the positively charged particle will attract the negatively charged particle, creating a force field between them. This force field acts as a barrier, preventing the particles from coming into contact with each other.
What is the role of the electric charge in creating the barrier?
The electric charge of the particles plays a crucial role in creating the electrostatic barrier. The magnitude of the charge and the distance between the particles determine the strength of the barrier. The higher the charges and the closer the particles are, the stronger the barrier will be.
Why is the electrostatic barrier important in physics?
The electrostatic barrier is essential in physics because it explains the behavior of charged particles and the forces between them. It also plays a crucial role in many phenomena, such as atomic and molecular interactions, nuclear fusion, and particle accelerators.
Can the electrostatic barrier be overcome?
Yes, the electrostatic barrier can be overcome by providing enough energy to the charged particles to break through the force field. This can be achieved through various methods, such as increasing the speed of the particles or using high-intensity electric fields.
  • Electromagnetism
  • Electromagnetism
