What is baseline wandering in digital transmission?
In summary, baseline wandering is a problem caused by different levels in the transmitter and receiver, which can cause data errors.
Geek007
hi there,
can someone please explain what is baseline wandering and how the continues 1's and 0's cause baseline wandering in digital transmission?
Regards
Because the transmitter and receiver often have different electrical requirements, sometimes you have to AC couple the signal, which means you put a series capacitor in the circuit that blocks the DC component of the transmitted signal.
Now, remember that DC is just the average value of the signal. Imagine you are using the simplest tranmission scheme, which is Pulse-Amplitude modulation, Non-return-to-zero (PAM-NRZ). This means the voltage is high for 1, low for 0. Also, say that in your transmission system the level for 1 is 2V higher than for 0, or as it is often described, the signal alternates between 1 and -1 V (relative to the DC level).
Some examples:
If you have an equal number of 1s and 0s, the average value is 0.5*1 + 0.5*(-1) = 0. Which is what you expect.
If you have 9 1s on average for each 0, your average value you be 0.9*1 + 0.1*(-1) = 0.8.
If you have all 1s, the average value is just 1.
As you can see, this is no good because the DC level at the receiver is data dependent and this causes all kinds of problems.
There are various ways to fix this. For example:
  1. DC couple your TX and RX
  2. Use a "DC balanced" line code. Basically encode the data such that 1s and 0s are approximately zero (even if they aren't in your real data). Examples of a DC balanced line code are Manchester encoding or 8b-10b encoding.
  3. Use a DC restoration circuit. Basically a slow filter which holds the baseline as the data changes.
Likes Geek007, anorlunda and berkeman
In more severe cases,you may even have to use frequency modulation for 1 0 encoding.
Manchester coding - AKA Biphase coding avoids variable DC offset by sending a 1 as 01 and 0 as 10 ( or the other way round) so each binary digit has a mean value of 1/2. It involves doubling the bit rate, of course, but the analogue bandwidth needed to transmit biphase need not be excessive.
Likes anorlunda
Related to What is baseline wandering in digital transmission?
1. What is baseline wandering in digital transmission?
Baseline wandering is a common phenomenon in digital transmission where the baseline or reference level of a digital signal shifts or drifts from its original position. This can result in distortion or corruption of the transmitted signal, making it difficult to accurately interpret the data.
2. What causes baseline wandering in digital transmission?
Baseline wandering can be caused by various factors, such as noise interference, changes in the transmission medium, or imperfections in the transmitter or receiver equipment. It can also occur due to the presence of low-frequency components in the transmitted signal.
3. How does baseline wandering affect digital transmission?
Baseline wandering can lead to errors in the transmitted data, as the shifting baseline can cause the signal to be misinterpreted by the receiver. This can result in data loss or corruption, leading to the need for retransmission and potentially slowing down the communication process.
4. Can baseline wandering be prevented?
While it is not possible to completely prevent baseline wandering, it can be minimized by using proper signal conditioning and filtering techniques. This can help reduce noise interference and maintain a stable baseline, resulting in more accurate transmission of data.
5. How is baseline wandering corrected in digital transmission?
Baseline wandering can be corrected by using various techniques such as signal equalization, adaptive filtering, or digital signal processing algorithms. These methods help to restore the baseline to its original position and minimize the effects of baseline wandering on the transmitted data.
  • Electrical Engineering
