What is Boundary Interaction in Echolocation and Internal Body Structures?
Physicsman788
New poster has been reminded to show their work on schoolwork problems
What is a boundary and how can boundary interactions be used in echolocation and examining internal body structures?
N/A
Please familiarize yourself with our forum rules especially item 4 here. You must make an attempt to answer the question.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
