- 19,464
- 10,078
Definition/Summary
The Cayley-Dickson construction is a way of getting algebras from other algebras. The starting algebra must have addition, multiplication, and conjugation defined for it, and the new algebra has pairs of elements of the starting algebra with appropriately defined operations on those pairs.
Starting with the real numbers, one finds the complex numbers, the quaternions, the octonions, the sedenions, and higher 2^n-ions. From the real numbers to the sedenions, one loses properties, though one does not lose properties after the sedenions.
Equations
The starting algebra A must have these operations:
Scalars: real numbers
Addition (+): A is an abelian group over +
Multiplication (.): distributive over +
Conjugation (*): satisfies (a*)* = a, (a + b)* = (a*) + (b*), (a.b)* = (b*).(a*)
The resulting algebra B has elements (a,b), with a,b in A, that satisfy these versions of addition, multiplication, and conjugation:
[itex](a_0,a_1) + (b_0,b_1) = (a_0+b_0,a_1+b_1)[/itex]
[itex](a_0,a_1)\cdot(b_0,b_1) = (a_0 b_0 - b_1 a_1^*, a_0^* b_1 + b_0 a_1)[/itex] (Baez)
[itex](a_0,a_1)\cdot(b_0,b_1) = (a_0 b_0 - b_1^* a_1, b_1 a_0 + a_1 b_0^*)[/itex] (Wikipedia)
[itex](a_0,a_1)^* = (a_0^*,-a_1)[/itex]
One can define a norm
[itex]||a|| = a a^*[/itex]
and if it is nonzero for element a, a multiplicative inverse
[itex]a^{-1} = \frac{a^*}{||a||}[/itex]
Also real and imaginary parts
[itex]\text{Re } a = \frac12(a + a^*)[/itex]
[itex]\text{Im } a = \frac12(a - a^*)[/itex]
Extended explanation
To illustrate the Cayley-Dickson construction in action, start with the real numbers and repeat that construction on it. For real numbers, conjugation is the identity operation, x* = x. One finds:
[itex]x^n = P(n,x_r,||x_i||) + x_i Q(n,x_r,||x_i||)[/itex]
where P and Q satisfy the addition laws
[itex]P(n_1+n_2,a,b) = P(n_1,a,b) P(n_2,a,b) - b Q(n_1,a,b) Q(n_2,a,b)[/itex]
[itex]Q(n_1+n_2,a,b) = P(n_1,a,b) Q(n_2,a,b) + Q(n_1,a,b) P(n_2,a,b)[/itex]
The norm satisfies
[itex]||x^n|| = ||x||^n[/itex]
and the inverse power is
[itex]x^{-n} = (P(n,x_r,||x_i||) - x_i Q(n,x_r,||x_i||))/||x||^n[/itex]
The first few values:
P(0,a,b) = 1, Q(0,a,b) = 0
P(1,a,b) = a, Q(1,a,b) = 1
P(2,a,b) = a2 - b, Q(2,a,b) = 2a
P(3,a,b) = a3 - 3ab, Q(3,a,b) = 3a2 - b
Automorphism groups:
Equations
- R: real numbers (1)
- C: complex numbers (2)
- H: quaternions (4)
- O: octonions (8)
- S: sedenions (16)
- Higher 2n-ions
- Additive identity: all components zero
- Multiplicative identity: real part 1, imaginary part 0
- Self-conjugate: R
- Multiplication commutative: R, C
- Multiplication associative: R, C, H
- Multiplication alternative: R, C, H, O
- Normed multiplication: R, C, H, O
- Zero divisors: S, higher
- Multiplication power-associative: all
- Matrix representations are only possible when multiplication is associative. Thus, the octonions and higher -ions do not have them.
- The alternative property is two-element associativity: a.(b.b) = (a.b).b, b.(a.b) = (b.a).b, b.(b.a) = (b.b).a
- Normed multiplication: ||a.b|| = ||a||.||b||
- Zero divisors are nonzero numbers which yield zero when multiplied by certain other nonzero numbers
- Power-associativity is forming a power of an element being independent of the order of multiplication
The norm satisfies
- R: identity group
- C: Z(2) - conjugation
- H: SO(3) - rotation of the imaginary part
- O and higher: G2, the smallest exceptional Lie group
