What is considered the "System" here? (conservation of energy problem)
In summary, the difference between W-E principle and conservation of energy is that we simply consider the work done by the 'external' forces (if solely the object is considered) from Wnet=changeofK in terms of energies itself (if system is considered as a whole).
simphys
324
46
see picture please
nothing
So in this picture friction is also assumed, but if we assume friction as an energy don't we need to consider the system to be earth, roller-coaster car, roller-coaster itself(due to friction force)? I actually still had this question from a previous coverage of this material lol...
I just understood that the difference between W-E principle and conservation of energy is that we simply consider the work done by the 'external' forces (if solely the object is considered) from ##W_net=changeof K## in terms of energies itself (if system is considered as a whole) divided into NC and C forces of course.
i.e. two different points of view for the problem. #howamazingisthat :P
I always looked at it as it being a different way to solve the problem but not that it's an acutal substitute of the work done into a form of energy.
anyways... here is the question
simphys said:
Homework Statement:: see picture please
It's pretty useless. Don't be lazy: type the problem statement and your attempt at solution.
And read back what you post.
  • Sad
Likes vela, Orodruin, Delta2 and 2 others
What do you mean about lazy?? it's really a simple question that doesn't need any calculation? :)
My question is why don't we considered the roller-coaster (for the friction force) as well to be compliant with the law of conservation of energy. Instead only the roller-coaster car and the Earth is considered as being the system
Relevant Equations:: nothing
You can consider the friction on the car as an external force on the car+earth system.
I've read that ten times and still don’t get what it means. Work done = change in KE applies to rigid bodies, not the car+earth system.
Likes simphys and Delta2
and what if I said that it is a thermal energy, would it be included into the system? (obviously not practical) but just wondeirng.
edit: clarification. Let me rephrase:
What if I said that the work done by the friction force is a thermal energy, do I consider the roller-coaster also to be included in the (car+earth) system?
Haha, yeah nvm I'll delete it😬, hahaha indeed the object itself is what I meant, not the system. What I meant was that I was always looking at the conservation of energy as a totally different approach to solve the problem, but it is a change of work done by forces (from the work done = change in KE) into either potential energy for conservative forces or work done(/thermal energy) for nonconservative forces and then equate that to KE which gives us the law basically.
Because of not understanding this I was kind of struggling on getting electric PE on an intuitive level. It all comes down to the fact that the coulomb force (or lorentz force more generally) is seen as a conservative force
No, by definition, the car+earth system does not include the roller coaster structure. And the work done by the friction on the system is negative KE.
Likes simphys
Could you please tell me why by definition? Because it just said it like this potential energy is a property of the system chosen (system = collection of objects that we choose to study) But nothing really on how or why it can't be chosen. and oh yeah due to the movement of the particles internally got it.
If all you're interested in is the PE and KE of the car in relation to the Earth there's no point in including the trackwork.
If you order a delivery pizza, which company advertises "30 min or free", your interest is in the elapsed time, not the traffic, nor competence of the driver, nor anything else that can affect it.
@OP I noticed in your scribbles that you question why the Normal force changes as the car rolls along... has that been cleared up ?
It is not about being an easy question or not, it is about attaching an image of the problem instead of typing it out. Even if it was a high quality image that was easy to read (it is not) there are several issues with this in terms of quoting text in replies etc (and it is also not in line with the homework guidelines). If you expect people to spend time to help you for free, the least you can do is to not make it harder for them to do so by being lazy.
Likes simphys, hmmm27, berkeman and 2 others
Yes, because friction will heat up both the car and track. The conservation of energy equation would be
$$K_{\rm i, car} + U_{\rm i, car} = K_{\rm f, car} + U_{\rm f, car} + \Delta E_{\rm th, car} + \Delta E_{\rm th, track}.$$ Friction would be the mechanism by which mechanical energy is turned into thermal energy.
If all you really care about is that the energy dissipated by friction reduces the mechanical energy of the car, you can leave the track out of it, ignore the increases in thermal energy, and just talk about the work done by friction. That's how the book solved the problem.
Because that is what "car+earth system" means. You could choose a car+earth+structure system, but the author has chosen just car+earth. You cannot dispute someone else's choice of system. You can dispute whether it is the best choice, and you can dispute the equations they write concerning it.
Now, strictly speaking, there is some tiny gravitational attraction between the car and the structure, but we can safely ignore that. So the variation in potential energy is in the relative positions of car and earth. The author wishes to make that internal energy, so takes car+earth as the system. But she wants the friction to be an external force, so leaves out the structure.
right. It has nothing to do with laziness, just my evaluation of the situation deciding to put up the picture as it'd be easier to reference. And on which I didn't notice that the image was compressed causing the lower quality. I will do that next time.
May I ask what you mean with the quoting text part please? if you meant the W-E principle eq. I didn't know how to put up those supscripts indeed.
Yes thank you. It was from the previous time around.
Thank you, that was unfortunately not really mentioned and caused my confusion previous time around..
It'd be more suiteable then to only incoorporate it as an energy if you can actually reutilize it afterwards I presume (more complex processes)
thank you, it comes down to personal judgement for such situation, got it thanks.
And now that you mentioned the second part.
Let's say I have a mass and a spring right. Taking the mass-spring system, and assume that the spring is massless.
Which energies are we then able to neglect (from the spring)?
  • KE because of no mass alright(mentioned in the book). But, if it was considered what would its speed be the same as the mass or not?
  • and for Potential energy of the spring (not mentioned in the book that's why I'm double checking), will also be ignored due to no mass.
This is exactly the point. It is not easier to reference as we cannot quote particular parts of the text. Just as I am doing now.
https://www.physicsforums.com/help/latexhelp/
Likes simphys
Orodruin said:
This is exactly the point. It is not easier to reference as we cannot quote particular parts of the text. Just as I am doing now.https://www.physicsforums.com/help/latexhelp/
yep, got it thank you. Will do that next time :)
And thank you I will check that it.
Likes BvU
You have not completely specified the arrangement. Are you starting with a free standing spring on the ground, with a mass dropped on top?
sorry I was talking sideways in the x-direction because otherwise there would be grav PE
A spring is not a rigid body. You would have to consider how the mass elements of the spring move. It could even happen that the spring does not expand uniformly, leading to waves propagating along it.
Likes simphys
Which potential energy? If it is sideways then presumably you do not mean GPE, but you obviously can't ignore EPE (elastic PE).
Likes simphys
I thin grav PE(for the spring) was assumed because I was talking about it in the y-dir not the x-dir. as stated, but anyways doesn't really matter my apologies. it was more the KE I was not so sure about how it would be involved once taken into acount.
Oh okay, so that's basically a more advanced treatment hence why we ignore the mass of the spring.
FAQ: What is considered the "System" here? (conservation of energy problem)
What is meant by the term "system" in the context of conservation of energy?
The term "system" refers to a specific object or group of objects that are being studied in relation to energy. In the context of conservation of energy, the system refers to the objects or particles involved in a specific energy transformation or transfer.
How do you determine what is considered the "system" in a conservation of energy problem?
In order to determine the system in a conservation of energy problem, you must identify the objects or particles that are involved in the energy transformation or transfer. These objects or particles make up the system and are the focus of the energy analysis.
Can the system change in a conservation of energy problem?
Yes, the system can change in a conservation of energy problem. As long as the energy transformation or transfer being studied involves the same objects or particles, the system can change from one step of the problem to the next.
Is the system always closed in a conservation of energy problem?
Not necessarily. In some cases, the system may be considered closed if there are no external forces or energy inputs/outputs acting on it. However, in other cases, the system may be open if there are external factors that can affect the energy involved.
Why is it important to identify the system in a conservation of energy problem?
Identifying the system is important because it allows for a focused analysis of the energy involved in a specific transformation or transfer. It also helps to determine the boundaries of the problem and what factors may be influencing the energy. Without clearly defining the system, it can be difficult to accurately apply the principle of conservation of energy.
