- #36
- 10,798
- 3,667
Yuriy Zayko said:I have been dealing with this problem for two years and proposed my solution in the article Y.N. Zayko, The Geometric Interpretation of Some Mathematical Expressions Containing the Riemann zeta-Function, Mathematics Letters, 2016; 2 (6): 42-46.
Very very interesting stuff. It emboldened me to explain, as promised, Ramanujan Summation - which I do below. The conclusion I have reached is its simply writing, in a reasonable way, the series so it can be summed.
It's based on the Euler-Maclauren series, a not what I would call rigorous, but short, derivation I will now give. Define the linear operator Ef(x) = f(x+1). Define Df(x) = f'(x). Also f(x+1) = f(0) + f'(x) + f''(x)/2! + f'''(x)/3! ... (the Maclauren expansion), or Ef(x) = f(x) +Df(x) + D^2f(x)/2! + D^3f(x)/3! ... = e^Df(x). We Also need the Bernoulli numbers which are defined by the expansion of x/(e^x - 1) = ∑B(k)*x^k/k! - you can look up the values with a simple internet search.
f(0) + f(1) + f(2) ... f(n-1) = (1 + E + E^2 ++++++E^(n-1))f(0) = (E^n -1/E-1)f(0) = (E^n -1)(1/e^D -1)f(0) = D^-1*(D/e^D -1)f(x)|0 to n = D^-1f(x)|0 to n + ∑ B(k)*D^(k-1)f(x)/k!| 0 to n = 0 to n ∫f(x) + ∑B(k)*D^(k-1)f(n)/k! - ∑B(k)*D^(k-1)f(0)/k!. Now the sum is from 1. Let n → ∞ and most of the time Sn = ∑B(k)*D^(k-1)f(n)/k! → 0 so we will assume that - certainly its the case for convergent series since → 0. So you end up with ∫f(x) - ∑B(k)*D^(k-1)f(0)/k!. So f(0) + f(1) + f2) +f(3) ...= ∫f(x) - ∑B(k)*D^(k-1)f(0)/k!. Notice regardless of n (- ∑B(k)*D^(k-1)f(0)/k!) does not depend on n and is called the Ramanujan sum. Again note the sum is from 1. We would like the Ramanujan Sum to be the same for concergent series. This is done by defining it as ∫f(x) + C where C is the Ramanujan sum. If it is finite then it is ∫f(x) + C. If it is infinite it is defined as C.
I won't go any further into it - you can look it up and see what various series give in various cases - it gives the good old -1/12 for 1+2+3+4... but with an interesting twist.
Thanks
Bill
