What Is Convolution in Mathematics?
In summary, convolution is a mathematical operation that combines two functions, f and g, to produce a third function. It is often used in functional analysis and has various interpretations, such as the area overlap between the two functions or the weighted sum of the two functions. It can be understood better with discrete time functions and is often calculated in the frequency domain. Convolution can be a difficult concept to understand, and it is recommended to seek out additional tutorials and examples to gain a better understanding of it.
Nat3
69
I'm really confused about the idea of convolution and could really use some help understanding it. Wikipedia says:
In mathematics and, in particular, functional analysis, convolution is a mathematical operation on two functions f and g, producing a third function that is typically viewed as a modified version of one of the original functions, giving the area overlap between the two functions as a function of the amount that one of the original functions is translated.
Emphasis added.
It seems to me that since the two functions are being multiplied together and then integrated that the integral should give the product of the areas of the two functions where the two functions overlap. My interpretation is significantly different than the rest of the world's, so I guess I'm wrong?
Anyone?
Emphasis added.
I assume you are learning this for a class? I learned it in a Signals Processing class and we used it to find responses of linear systems to inputs using the impulse response h(t), and some input f(t).
The integral has a graphical interpretation that is light to compute by hand for many inputs and impulse responses. This leads to the "multiplication of areas" interpretation but that does somewhat disguise what's going on. The idea of the convolution integral being directly proportional to the area under one of the two functions being convolved is only true when one of the integrals is a flat function. (ie constant c or 0 for some time intervals). And indeed, this area is a product as you say between the two functions, but not between their areas. It's the area under one function, whose integrand is weighted by the other function and vice versa. I hope this helps.
Consider an example. A radar unit sends out a pulse that is reflected off a target. The transmitted pulse has a time duratation. If the target has depth, the relected pulse may be the sum of the pulse length and the target depth. If the transmitted pulse is not square and if the target presents multiple edges, the returned pulse may have a complex shape. For imaging it would be important to subtract the transmitted pulse shape from the reflected pulse shape and this would be done with deconvolution.
I believe you are wrong. Imagine each area as a series of thin vertical strips (same "time segment"). Each strip of the foreground function is weighted by the strip of the background function and these weighted results are then added (summed) by the integral. This way the integral is actually the foreground area weighted in each of its value ("time segment") by the appropriate value in the background area instead of -- how you present it -- the surface of entire foreground area weighted by the surface of entire background area.
I'm quite confident that if you draw 2 functions (one triangle facing left and one triangle with different slope facing right) and calculated their convolution that the weighted strips vs. weighted areas would stand out.
I found it easier to understand convolution with time discrete functions, i.e. functions that have a value only every say 1 second. Draw one function (the "filter") with only about 5 different values, draw the other function (the "signal") with about 10 different values, flip the signal function around y-axis as you are required for convolution and start sliding them on top of each other and calculate a few values of the output function. You'll see why I recommended to create "time segment" or "time slices", you'll see how each value at each time is weighted with the same value of the filter and how they are then added/summarized to create one resulting value for that given time difference (addition is discrete-time equivalent of integral for continuous time functions).
Don't feel bad if you can't understand convolution. I think I really realized what convolution is only about 10 years after graduating from university and my studies were heavily based on signal processing :smile: It's just that sometimes some professors completely drown basic concepts in heavy mathematics.
Convolution as explained this way is how it works in time-domain. In frequency domain you just multiply the two functions (which are Fourier/Laplace images of time-domain functions) and you are done. That's why everybody calculates convolution in frequency domain :biggrin:
Check external links on Wikipedia for other tutorials on convolution. Maybe you'll find there something that speaks more to you.
Basically I think convolution is the summation of signal functions from one minimum value to a maximum value: (0 to 2 ) Ʃ v[n - i ] ⇔ v[n] + v[n-1] + v[n-2] . The brackets mean that we are using discrete time I think.
Discrete time convolutions tutorials
I meant to say "discrete time functions".
I just checked Google for "discrete convolution" and "discrete time convolution" and there are some really nice tutorials and graphical explanations out there. Check out the accompanying images (discrete convolution, discrete time convolution).
Also, in looking for tutorials, try to avoid examples which use constant functions ("rectangles") and linear slope triangles. I believe they may give you a wrong ideas about certain properties of convolution or its true meaning.
Related to What Is Convolution in Mathematics?
What is convolution?
Convolution is a mathematical operation that combines two functions to create a third function that represents how the shape of one function is modified by the other. In the context of signal processing and image processing, it is used to extract features from signals and images.
How is convolution used in science?
Convolution is widely used in various scientific fields, including physics, engineering, and biology. It is used for signal processing, image processing, and data analysis. In physics, it is used to model physical systems and analyze signals from experiments. In biology, it is used to analyze DNA sequences and protein structures.
What is the difference between 1D and 2D convolution?
1D convolution is used for processing one-dimensional signals, such as audio signals or time series data. 2D convolution is used for processing two-dimensional signals, such as images. The main difference is that 2D convolution takes into account both the horizontal and vertical dimensions of the signal, while 1D convolution only considers the horizontal dimension.
How does convolution relate to deep learning?
Convolutional neural networks (CNNs) are a type of deep learning model that uses convolution to extract features from images. The convolutional layers in a CNN apply filters to the input image, which helps to identify patterns and features in the image. This process is repeated multiple times, with the output of each layer feeding into the next layer.
What are some real-world applications of convolution?
Convolution has many applications in the real world, including image and video processing, speech recognition, and medical imaging. It is also used in natural language processing, such as text classification and sentiment analysis. Additionally, convolution is used in scientific research for data analysis, pattern recognition, and simulation modeling.
