What is dark energy in the fabric of space-time?
In summary: Now, having a definition of space and spacetime, lets try and describe what dark energy is.In summary, dark energy is the unknown form of energy that is causing the universe to expand.
Daine
I know that according to Einstein's theory of relativity, space-time is like a fabric which can be pliable. Gravity is the shape, or the warping of that fabric. In this analogy, what would dark energy (the unknown form of energy that is causing the universe to expand) be?
Space news on Phys.org
That is an attempt to explain the theory to laymen.
And that is taking the analogy too far already.
As mentioned these desciptives are heuristic attempts to describe spacetime.
First let's start off with the proper definitions, space is the volume under geometry. That volume requires 3 dimensions to describe. x,y,z which are your spatial dimensions.
Spacetime is any coordinate system that describes time via its interval between measurement points under a coordinate basis. We describe the interval via a new coordinate ct where c is not the speed of light but a constant of proportionality. Giving us (ct,x,z) this gives us a relation to the length element with which we can now graph into a spacetime diagram.
Now that we have our coordinate basis, we can assign a value or function at each of those coordinates. The value assigned being freefall motion. ( constant velocity ie no change in direction or speed).
Now under Euclidean flat geometry with time for 4d, with time given the dimension of length. Galilean relativity applies. This is our everyday experience (Newtonian physics) with no time variation.
Our geometry is preserved and will follow all vector summation rules. Pythagorous theorem of lengths and angles are preserved.
However due to how signals propogate between separation points at higher potentials and as the velocity approaches c.
This no longer holds accurate, we start to deviate in the signal intervals. This is defined by the simultaneous changes on two of our coordinate axis. ct and x. To which we can assign a new constant of proportionality to restore our Euclidean geometry. That being [tex]\gamma[/tex]
Galilean relativity transforms,
[tex]\acute{x}={x}-vt[/tex]
[tex]\acute{y}=y[/tex]
[tex]\acute{z}=z[/tex]
Lorentz Transforms
[tex]\acute{x}=\gamma x-vt[/tex]
[tex]\acute{t}=\gamma (t-\sqrt{\frac{vx}{c^2}})[/tex]
lets make sure you understand this first before going into the [tex]ds^2[/tex] separation distances between two points under polar coordinates. The above is Cartesian, and you have a learning curve to understand the cosmological constant which can be shortened by reading the following.
http://cosmology101.wikidot.com/universe-geometry
page 2 which has the geometric relations of interest with regards to cosmology applications of the above.
http://cosmology101.wikidot.com/geometry-flrw-metric/
Related to What is dark energy in the fabric of space-time?
1. What is dark energy in the fabric of space-time?
Dark energy is a hypothetical form of energy that is believed to make up about 70% of the universe. It is thought to be responsible for the accelerated expansion of the universe and is believed to be present in the fabric of space-time.
2. How is dark energy different from dark matter?
Dark energy and dark matter are two separate concepts. Dark matter is a form of matter that does not emit or interact with light, while dark energy is a form of energy that is thought to be responsible for the expansion of the universe. They are both called "dark" because they cannot be directly observed, but they have different properties and effects on the universe.
3. How do scientists detect or measure dark energy?
Scientists use various methods to detect and measure dark energy, including studying the expansion of the universe through observations of supernovae and analyzing the cosmic microwave background radiation. The effects of dark energy on the large-scale structure of the universe can also be studied through gravitational lensing and the growth of galaxy clusters.
4. What are some theories about the nature of dark energy?
There are several theories about the nature of dark energy, including the cosmological constant theory, which suggests that dark energy is a constant force that permeates the universe. Other theories propose that dark energy is a new type of energy field or a manifestation of the effects of gravity on a large scale.
5. Can dark energy be harnessed for practical use?
At this time, there is no known way to harness dark energy for practical use. Its effects are only observable on a cosmic scale and are not yet fully understood by scientists. However, further research and advancements in technology may lead to potential applications of dark energy in the future.
  • Cosmology
  • Cosmology
