What is density of dark matter as a function of distance from the galactic core?
The discussion focuses on calculating the density of dark matter as a function of distance from the galactic core. The mass of dark matter, denoted as M2(r), is derived from gravitational equations, leading to the formula M2(r) = (v0^2/G)(r - r1). An average density over a specified interval is calculated, and as the interval approaches zero, the density function is simplified to ρ(r) = (v0^2)/(4πr^2G). Participants confirm the correctness of the calculations and the derived formula for dark matter density.
Lotto
Because of dark matter, our stars in the Galaxy with core of radius ##r_1##, whose matter is distributed spherically symetrically, are moving with speed ##v_0## that is not dependent on distance from the Galaxy's centre. This is true for distances from the centre smaller than ##r_2##. Consider the distribution of dark matter to be spherically symetric around the centre. What is denisty of dark matter dependent on distance ##r## from the Galaxy's centre in interval from ##r_1## to ##r_2##?
##G\frac{mM}{r^2}=m\frac {{v_0}^2}{r}##
##M_1=\frac{{v_0}^2r_1}{G}##
This problem builds on my previous post, where we calculated that core's mass is ##M_1=\frac{{v_0}^2r_1}{G}##. So if we consider mass of dark matter dependent on distance ##r## to be ##M_2(r)##, we can calculated it from
##G\frac{(M_2(r)+M_1)m}{r^2}=m\frac{{v_0}^2}{r}.##
So ##M_2(r)=\frac{{v_0}^2}{G}(r-r_1)##.
An average density in interval from ##r## to ##r+\Delta r## is ##\frac{\frac{{v_0}^2}{G}(r+\Delta r-r_1)-\frac{{v_0}^2}{G}(r-r_1)}{\frac 43 \pi [(r+\Delta r)^3-{r_1}^3]-\frac 43 \pi (r^3-{r_1}^3)}##. If we make a limit of it for ##\Delta r \rightarrow 0##, we get
##\rho(r)=\frac{{v_0}^2}{4\pi r^2G}##.
Is it correct? If not, where are my thoughts wrong?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
