What is different in Solar Radio vs Radio Flux 10.7 cm?
In summary, the site says that Solar Radio Flux is a measure of diffuse, nonradiative heating of the coronal plasma trapped by magnetic fields over active regions, and is an excellent indicator of overall solar activity levels. The solar F10.7 cm record extends back to 1947.
junk0
40
Referring to following links, I would like to know whether Solar Radio is equal to Radio Flux or not, it seems that it describes Solar Radio in different format.
Are they monitoring the same objects?
Does anyone have any suggestions on what the different is between them?
Thanks in advance for any suggestions
Radio Flux 10.7 cm
http://www.swpc.noaa.gov/ftpdir/weekly/27DO.txt
Solar Radio at different Freq
http://www.swpc.noaa.gov/ftpdir/lists/radio/rad.txt
4 minutes ago - 4 days left to answer.
Astronomy news on Phys.org
The site says the following:
Forecasts of 10.7 cm solar radio flux are integer forecasts of the daily observed flux at 2800 Mhz (10.7 cm) in solar flux units (10-22W m-2 Hz-1)
http://www.swpc.noaa.gov/forecast_verification/F10.html
Your second link has multiple frequencies listed, not just the 10.7 cm wavelength, but they are measured in the same units.
Thanks you very much for suggestions
I get some questions not understand well about Solar Radio Flux.
Questions about Solar Radio Flux
Referring to following image, I would like to know how to define the measured units for Solar Radio Flux.
http://i1093.photobucket.com/albums/i438/junk000/Radio.jpg
http://www.swpc.noaa.gov/ftpmenu/lists/radio.html
For example,
Under column for 0500 UTC, will it refer to period starting from 0500 UTC to 1200 UTC?
Under column for 0500 UTC, will it refer to period starting from 2300 UTC to 0500 UTC?
Under the row for 410 Freq MHZ, wiill it referring to range starting from 245 to 410 Freq MHZ?
Under the row for 410 Freq MHZ, wiill it referring to range starting from 410 to 610 Freq MHZ?
Referring to following linked image, the data for solar radio flux are always missing for periods 500 UTC and 1200 UTC.
Do you have any suggestion? Will equipment be turned off during this period?
Thanks you very much for any suggestions
Referring to following link, F10.7 represents a measure of diffuse, nonradiative heating of the coronal plasma trapped by magnetic fields over active regions. Does it represent a measure of amount of charges particles within plasma as well? which is Electric Flux Density.
I am so confused, does anyone have any suggestions?
Thanks everyone very much for any suggestions
http://en.wikipedia.org/wiki/Solar_cycle#Solar_radio_flux
Solar radio flux
Emission from the Sun at centimetric (radio) wavelength is due primarily to coronal plasma trapped in the magnetic fields overlying active regions.[17] The F10.7 index is a measure of the solar radio flux per unit frequency at a wavelength of 10.7 cm, near the peak of the observed solar radio emission. F10.7 is often expressed in SFU or solar flux units. It represents a measure of diffuse, nonradiative heating of the coronal plasma trapped by magnetic fields over active regions, and is an excellent indicator of overall solar activity levels. The solar F10.7 cm record extends back to 1947, and is the longest direct record of solar activity available, other than sunspot-related quantities.
Solar radio and radio flux 10.7 cm are two different measurements used to study the Sun. While they both involve radio waves, they are not equal to each other.
Radio flux 10.7 cm is a measurement of the radio emissions at a specific wavelength of 10.7 centimeters from the Sun. This measurement is often used as an indicator of solar activity and can be used to track changes in the Sun's overall magnetic field. It is typically measured by ground-based instruments and reported by organizations such as the National Oceanic and Atmospheric Administration (NOAA).
On the other hand, solar radio refers to the entire range of radio emissions from the Sun, not just those at a specific wavelength. These emissions can occur at different frequencies and can provide information about different phenomena happening on the Sun, such as solar flares or coronal mass ejections. Solar radio is typically measured by radio telescopes and reported in a different format than radio flux.
So while both measurements involve radio waves and are used to study the Sun, they are not equal to each other. They provide different types of information and are measured in different ways. It is important to note that they are not monitoring the same objects, but rather different aspects of the Sun's activity.
In summary, the main difference between solar radio and radio flux 10.7 cm is the type of information they provide and how they are measured. It is important to understand the distinction between the two in order to properly interpret and use the data they provide.
Related to What is different in Solar Radio vs Radio Flux 10.7 cm?
1. What is the main difference between solar radio and radio flux 10.7 cm?
The main difference between solar radio and radio flux 10.7 cm is the source of the radiation. Solar radio emissions originate from the Sun, while radio flux 10.7 cm is a measure of the solar radio emissions received at Earth's distance from the Sun.
2. How are solar radio and radio flux 10.7 cm related?
Solar radio and radio flux 10.7 cm are closely related as they both measure the intensity of radio emissions from the Sun. However, radio flux 10.7 cm is a standardized measurement, while solar radio can refer to a broader range of frequencies and emissions.
3. What is the unit of measurement for solar radio and radio flux 10.7 cm?
The unit of measurement for both solar radio and radio flux 10.7 cm is watts per square meter per hertz (W/m2/Hz). This unit represents the power or energy per unit area and frequency.
4. Are there any differences in the data collected for solar radio and radio flux 10.7 cm?
Yes, there are differences in the data collected for solar radio and radio flux 10.7 cm. Solar radio data can include a wider range of frequencies and may also be affected by interference from other sources, while radio flux 10.7 cm data is typically more standardized and controlled.
5. How are solar radio and radio flux 10.7 cm used in scientific research?
Solar radio and radio flux 10.7 cm are used in a variety of scientific research, including studying the Sun's activity and its effects on Earth's atmosphere and space weather. They are also used to track and predict solar flares and other solar events that can impact satellite and communication systems.
  • Astronomy and Astrophysics
  • Electromagnetism
10K
