Definition of Displacement: Change in Position
  • Thread starter Greg Bernhardt
  • Tags
    Displacement
In summary, displacement refers to the change in position of an object, and can be represented as a vector or a scalar. In physics, displacement is used in equations such as work done and distance along a curve. It should be noted that scalar displacement is different from distance, as it only takes into account the magnitude of the vector displacement. In one-dimensional situations, vector and scalar displacement are the same except for the possibility of negative values. The concept of displacement is often discussed in relation to the metric used.
10,254
Definition/Summary
Displacement is change in position (of the same thing).
For example, in the physics of vibrations and stress, the displacement of each point in the material is the vector from its "natural" position to its present position.
And in mechanics, work done is force "dot" displacement, where displacement means the change in position of the point of application of that force.
Displacement is a vector, but the word also sometimes means the magnitude of that vector (a non-negative scalar): in examination questions, the context should make it clear which is intended.
Scalar displacement is different from distance: for example, if you go half-way round a square of side [itex]r[/itex], then you have gone a distance (or arc-length) of [itex]2r[/itex], but your displacement is only [itex]r\sqrt{2}[/itex]: and if you go all the way round, you have gone a distance of [itex]4r[/itex], but your displacement is [itex]0[/itex].
Displacement has dimensions of length ([itex]L[/itex]).
Equations
Vector displacement:
[tex]\mathbf{r}(b)\ -\ \mathbf{r}(a)[/tex]
Scalar displacement:
[tex]|\mathbf{r}(b)\ -\ \mathbf{r}(a)|[/tex]
Distance (arc-length) along curve defined by [itex]\mathbf{r}(t)\ =\ (x(t),y(t),z(t))[/itex]:
[tex]ds^2\ =\ (d\mathbf{r})^2[/tex]
[tex]s \ =\ \int\ ds \ =\ \int_a^b\ \sqrt{\mathbf{r}'\,^2}\ dt\ =\ \int_a^b\ \sqrt{x'\,^2 + y'\,^2 + z'\,^2}\ \ dt[/tex]
Extended explanation
In a one-dimensional situation, vector and scalar displacement are the same (arc-length from the "origin"), except that vector displacement can be "negative". :wink:
* This entry is from our old Library feature. If you know who wrote it, please let us know so we can attribute a writer. Thanks!
Mathematics news on Phys.org
If you do a forum or insight search on the keyword "metric" you will find plenty of examples and how displacement depends on the given metric.
FAQ: Definition of Displacement: Change in Position
What is the definition of displacement?
Displacement is a physical quantity that measures the change in position of an object from its initial point to its final point.
How is displacement different from distance?
Distance is a scalar quantity that measures the total length traveled by an object, while displacement is a vector quantity that measures the shortest distance between the initial and final positions of an object.
What is the unit of measurement for displacement?
The unit of measurement for displacement is typically meters (m) in the SI (International System of Units) system.
Can displacement be negative?
Yes, displacement can be negative. This indicates that the final position of an object is behind its initial position, or in the opposite direction from its initial movement.
How is displacement calculated?
Displacement is calculated by subtracting the initial position from the final position of an object. This can be represented by the equation: Δx = xf - xi, where Δx is displacement, xf is the final position, and xi is the initial position.
