What is eigen value, eigen vector etc and what is their physical significance?
In summary, eigenvalue/eigenvector is a mathematical term that describes a physical relationship. It has physical significance when applied to matrices that operate on vectors to produce new vectors.
dexterdev
194
-Devanand T
The eigen value/vectors are any vector-value pair with a special relationship to a transformation ...
if a transformation A applied to a vector v results only in scaling the vector, then the vector is called an eigenvector of A and the scale factor s is it's eigen-value. That "only" part is the meaning of "eigen". which is to say: If A.v=sv then v is an eigenvector of A with eigenvalue s.
These need have no physical significance at all - the terminology is mathematical and describes a mathematical relationship. However, some physical models turn out to employ this relationship so knowing about it is useful.
In sloppy language: if a vector is, for instance, also a solution to the schodinger equation, then some transformations on that vector may have eigenvalues. If it has real eigenvalues then the transformation corresponds to the act of measuring a physical property on the system described by the schodinger equation. The eigenvalue helps predict the results of actually performing that measurement.
I disagree. In any case when an operator describes something physical, its eigenvectors have direct physical significance. They usually form a basis of the space involved, and the corresponding eigenvalues describe the effect of the operator on the basis vectors. So we have, in a way, "principal" directions of the operator.
Yeah I was just going to say something similar to Voko. What Simon Bridge said is true, but there is a type of physical meaning you can have when it comes to eigenvectors/eigenvalues and it comes about in the following way.
When you look at how matrices operate on vectors to produce new vectors, the alternative to the eigenvalue problem is just some [itex]\tilde{A} \vec{v}_{1} = \vec{v}_{2}[/itex] where [itex]\vec{v}_{1}[/itex] is not in the same direction as [itex]\vec{v}_{2}[/itex]. However, there are special direction(s) in which the vectors are in exactly the same direction (and thus we have the eigenvector/value equation [itex]\tilde{A} \vec{v} = \lambda \vec{v}[/itex].) The directions are really what's important here, it doesn't really matter what magnitude the eigenvector has, because you could just multiply both sides of the equation by a scalar. Now if there exists a number of eigenvalues (and thus number of "special directions" associated with the matrix operation) equal to the dimensions of the vectors, one can represent the vectors with basis vectors that are in these "special" directions (the eigenvalues can't be all in the same direction, they will span a space of 'n' dimensions where 'n' is the number of eigenvalues/vectors.) What does this do for us? It allows us to write the complicated multilinear vector function, [itex]\sum_{j}{\sum_{i}{A_{ij} v_{i} \hat{e}_{j}}}[/itex], as a simple linear vector function, [itex]\sum_{i}{v_{i} \hat{e}_{i}}[/itex], where the unit vectors are in the special directions (usually called the "principal directions" which are along the "principal axes"..)
When physics problems that involve matrix operations are represented in a coordinate system composed of these principle axes, the problem takes on its simplest form. The physics are the most direct and simple. There is a real significance to these axes, they denote the natural symmetry of the physical object being described by the matrix equation. They give you huge insights into the salient features of the physical geometry of the problem.
Let's look at a physical case. In the polarization of materials (let's say some crystal) by an outside electric field, the crystal usually polarizes more easily (well.. differently) in certain directions. The different directions are the principle directions and are related to the structure of the atomic lattice. If one represents the applied electric field in the principal coordinate system, then the polarization of the crystal can be found quite easily, it's a simple vector function like "[itex]\vec{P} = \epsilon_{o} \chi \vec{E}[/itex]". Represent the electric field in some other coordinate system, such as cartesian coordinates that are not aligned with the principle axes and you get this monster: [itex]\vec{P} = \sum_{i}{\sum_{j}{\epsilon_{o} \chi_{ij} E_{j} \hat{e}_{i}}}[/itex]. Note that [itex]\vec{P}[/itex] is the polarization per unit volume of the material.
I was being very general - for instance, I was not restricting "vector" to things like displacement, and force, but the broader sense of being a member of a vector space in mathematics. So, a polynomial, for eg., is a vector. I had hoped that OP would have brought up those points but never mind.
I was attempting to answer the question as stated :) "What is the physical significance..." but there is a related question: "what is the significance to physics..." and dydxforsn has given a good example of that.
A very well known example is our habit of resolving vectors into perpendicular and parallel components to some other vector. We are decomposing the vector into orthogonal eigenvectors of transformations in space.
I second Bridge's comment above. I once read somewhere on this forum that any linear space can be expressed in matrix form such as the set of linear ODE's, which of course implies treating the space like a Euclidean space but the space doesn't exist physically: it is only a Mathematical way of treating the elements in the set. Since ODE's are widely employed in Engineering, the eigenvectors do have physical implications but they are not necessarily spatial depending on the applications. Of course ODE is just an example but vectors in Mathematics are really general as Bridge put it.
I find that you cannot define something too rigirously to someone who has no idea what it is in the first place.
Essentially, when we say something is an eigenvector of something, we mean that, taken a member of a vector space (be it an actual vector, a function etc), when an operator A is done on it, the resultant vector is simply the original vector multipled by a constant
So..A(p)=ap Here p is the element of the vector space, a is some constant, A is some operator.
Well that begs the question of what an operator is ... it seemed reasonable to guess that OP knows what a vector is, and is capable of googling "eigenvector" etc and so will have heard about operators ... but still is confused. This is why I said "transformation" instead - someone who has heard of vectors has likely heard of transformations. Of course, it's only a guess ;)
I think what we need now is input from OP to see if we've covered the confusion.
How about it dexterdev? Any of this help?
By the way, when was the time when the term "eigen" displaced the term "proper" in mathematical texts and parlance? I know that in physics it caught on early, the question is about mathematics.
Related to What is eigen value, eigen vector etc and what is their physical significance?
1. What is an eigenvalue and eigenvector?
An eigenvalue is a scalar value that represents the amount by which an eigenvector is scaled when it is multiplied by a given matrix. An eigenvector is a non-zero vector that, when multiplied by a matrix, remains in the same direction but may be scaled by a certain factor.
2. What is the significance of eigenvalues and eigenvectors?
Eigenvalues and eigenvectors are important because they allow us to understand the behavior of linear transformations on a vector space. They can also be used to find the directions in which a matrix stretches or compresses a given set of vectors.
3. How are eigenvalues and eigenvectors used in science?
Eigenvalues and eigenvectors are used in a variety of scientific fields, such as physics, engineering, and statistics. They are commonly used in data analysis, image processing, and in solving differential equations.
4. What is the physical significance of eigenvalues and eigenvectors?
In physics, eigenvalues and eigenvectors can represent important physical quantities, such as the energy levels of a quantum mechanical system or the principal axes of a rigid body. In engineering, they can be used to analyze the stability and behavior of structures under different conditions.
5. Can eigenvalues and eigenvectors have complex values?
Yes, eigenvalues and eigenvectors can have complex values. This is often the case when dealing with matrices that have complex entries. In this case, the eigenvectors may also have complex entries, but their magnitude and direction remain the same.
11K
  • Linear and Abstract Algebra
  • Quantum Physics
  • Other Physics Topics
