What is Gravity: Learn How It Attracts Objects
  • Thread starter nathankco
  • Tags
    Gravity
In summary: You would have to use the mass/volume relationship to figure out how much force is being exerted. In summary, gravity is the force of attraction between masses. Objects follow null geodesics (fancy phrase for 'straight lines') through this curved space so that, to our eyes, they appear to curve (like how a baseball curves back toward the ground). The more mass an object has, the stronger the gravitational field.
nathankco
I want to know what's gravity. <:D
How's it attract objects?
Anything that are massive and dense consist gravity?
We don't really know.
Current theory models gravity as a curvature of spacetime. Objects follow null geodesics (fancy phrase for 'straight lines') through this curved space so that, to our eyes, they appear to curve (like how a baseball curves back toward the ground).
It is the presence of mass that curves space, so anywhere there is mass (even the smallest atom), there will be some curvature of spacetime.
Mass tells spacetime how to curve; spacetime tells mass how to move.
There are a gazillion PF threads on the this topic for the reading.
Gravity is a pull from the Earth's mass.
Everything has gravity EVEN YOU. We try to attract things by our Gravitational field.
The more your mass the stronger gravational field.
Hence the reason why the moons gravity is less than the Earth's.
The equation to this is GM*m / r
GM is a gravitational constant m is the mass r is radius from center.
So for ex if you want to find your gravitational strength you muliply the constant (I forgot it) by you mass in Kg devided by how far the object is from you in m.
Or anything else.
F = G . m/r^2
(And you only need M and m if you are figuring total force between two objects)
Thankyou guys! Thankyou!
DaveC426913 said:
F = G . m/r^2
You left out M.
What do you mean by 'total force'? As opposed to what?
Gravity can mean force of gravity or acceleration due to gravity. I think that's what Dave is getting at. Though, usually the little m is the one reserved for test mass, and big M is used for body generating the pull.
Naturally, if two masses are comparable, you cannot use this formula directly.
FAQ: What is Gravity: Learn How It Attracts Objects
What is gravity?
Gravity is a natural force that attracts objects towards each other. It is responsible for the motion of planets, stars, and other celestial bodies in the universe.
How does gravity work?
Gravity is the result of the curvature of space-time caused by massive objects. The more massive an object is, the stronger its gravitational pull. This pull causes objects to move towards each other.
Who discovered gravity?
Sir Isaac Newton is credited with discovering the concept of gravity. He observed the motion of planets and developed the theory of gravity in the 17th century.
What are the factors that affect gravity?
The strength of gravity is affected by the mass and distance between two objects. The greater the mass, the stronger the gravitational pull. The farther the distance, the weaker the gravitational pull.
How is gravity related to weight?
Gravity and weight are related because weight is a measure of the force of gravity acting on an object. On Earth, the gravitational pull is constant, so our weight remains the same. However, on other planets with different gravitational pulls, our weight would be different.
