What Is h in Calculus Limits and Tangent Lines?
  • MHB
  • Thread starter Jayden1
  • Tags
    Line
In summary, the conversation discusses finding the slope of a tangent line to a curve at a given point. The general formula for the slope is derived and simplified using a quadratic function. The final equation involves taking the limit of the slope as h approaches 0, which gives the slope of the tangent line. The conversation also includes an example for clarification.
Jayden1
Basically I have no idea what this is trying to tell me. This is from the online lecture notes my lecturer put up. I have no idea what is going on, and no idea what h is.
scaled.php
1. Can someone please explain what is going on in steps, really simply.
2. what is h?
Mathematics news on Phys.org
Re: Help with limits/tangaent line
scaled.php
2. what is h?
Hi Jaden,
The graph of the quadratic equation \(f(x)=x^2\) is shown in the picture. \(P\) is the point \((1,1)\) and \(Q\) is the point \(\left(1+h,(1+h)^2\right)\) where \(h\) is any real number. According to the picture \(h\) should be a positive number as well. Note that both of these points are on the graph since they satisfy \(f(x)=x^2\).
The gradient of the line that joins the two point \(P\mbox{ and }Q\) is given by, \(\displaystyle\frac{(1+h)^2-1}{(1+h)-1}=\frac{(1+h)^2-1}{h}\). Which is given as the slope of \(PQ\).
Now we shall generalize this for any two points.
Let, \(P\equiv(x_1,f(x_1))\mbox{ and }Q\equiv(x_1+h,f(x_1+h))\). Then the slope(say \(m_{PQ}\)) of the line \(PQ\) will be,
\[m_{PQ}=\frac{f(x_1+h)-f(x_1)}{(x_{1}+h)-x_1}=\frac{f(x_1+h)-f(x_1)}{h}\]
Hope this clarified all your doubts.
Thank you very much. Yes it does.
Once you end up with the final equation, what needs to be done with that in order to get the tangaent of the curve at an instant? I know it involves finding the limit h -> 0 for the equation. But it still confuses in terms of how I should continue.
Note that \(h\) is the separation between the two x-coordinates of the points \(P\) and \(Q\). When, \(h\rightarrow{0}\) the point \(Q\) will converge to \(P\). Ultimately you will have the tangent line. The gradient of the tangent(we shall denote this by \(f'(x_1)\)) is therefore given by,
\[f'(x_1)=\displaystyle\lim_{x\rightarrow 0}\frac{f(x_1+h)-f(x_1)}{h}\]
Now consider our function \(f(x)=x^2\). Try to substitute for \(f(x_1+h)\mbox{ and }f(x_1)\) in the above equation.
The limit as \(h \to 0\) gives you the slope \( m \) of the tangent. You have found the slope to the curve at the point \((1,1)\), so the tangent is the line:
\( y=m x +c\)and as it passes through \( (1,1) \) you have:
\(1=m + c\)
or
\(c=1-m\)
CB
Wait, so say we have f(x) = x^2
let a be the x value of point 1.
P1 = (a, f(a))
P2 = (a + h, f(a + h))
using the formula m = (y2 - y1) / (x2 - x1)
We get:
m = (f(a + h) - f(a)) / ((a + h) - a)
which then becomes:
m = (((a + h)^2) - (a^2)) / ((a + h) - a)
which is then simplified to:
m = (((a + h)^2) - (a^2)) / h
Am I right?
I hope you meant "Let a be the x value of point P1"
P1 = (a, f(a))
We get:
which then becomes:
Am I right?
Yes, of course you are correct. So the slope of \(P_{1}P_{2}\) is \(\displaystyle m = \frac{(a + h)^2-a^2} {h}\). But this can be further simplified. Try to expand the square in the numerator.
(a^2 + 2ah + h^2) / h
Incorrect. The original fraction is, \(\displaystyle m = \frac{(a + h)^2-a^2} {h}\). You have expanded \((a+h)^2\) but what about the \(-a^2\) term?
woops
2ah + h^2 / h
Jayden said:
woops
2ah + h^2 / h
You can simplify further. Try to factor the numerator and cancel what is common to both the numerator and the denominator.
2ah + h^2 / h
h(2a + h) / h
h(2a) / 1
2ah / 1
2ah?
Jayden said:
2ah + h^2 / h
h(2a + h) / h
h(2a) / 1
2ah / 1
2ah?
Almost.
\(\displaystyle \frac{2ah+h^2}{h}\)
\(\displaystyle \frac{h \left(2a+h \right)}{h}\)
\(\displaystyle 2a+h\)
So the h in the numerator and denominator cancel and the above line is what you are left with.
Jayden said:
woops
2ah + h^2 / h
You must use grouping symbols around the numerator to be correct:(2ah + h^2)/hOtherwise, what you typed is equivalent to:
[tex]2ah \ + \ \dfrac{h^2}{h}.[/tex]
Howcome you cancel the h outside the brackets instead of the other h? Is that because the other h is inside brackets and therefore attached to the 2a?
Hi Jayden,
Brackets are used to specify the order of operations. If you write, \(h(2a+h)\), this means that you have to add \(2a\mbox{ and }h\) first and then multiply it with \(h\). You can consider, the things which are inside the parenthesis as one unit. Now you have, \(\dfrac{h(2a+h)}{h}\), you have to multiply \(h\) with \(2a+h\) and divide the answer by \(h\). Multiplication and division have the same order of precedence and therefore you can divide the \(h\) in the numerator by the one in the denominator.
To refresh yourself about the order of operations I kindly suggest you to read, this and this.
Kind Regards,
Sudharaka.
I have a question. This one always gets me.
Say we have \(\dfrac{9x^2 + 5}{3x^2}\), does that make it \(\dfrac{6x^2 + 5}{1}\)
Also if we have \(\dfrac{6x^2 + 5}{18x^2}\), what would be the simplified answer? This got me in my last test.
EDIT: uhh how do you display fractions in that font?
You might need some time to learn the Latex syntax. We have a forum http://www.mathhelpboards.com/forums/26-LaTeX-Help with good information on how to get started. Also, this is a new topic so please start a new thread. We are more than happy to help you and very happy you are here! :)
FAQ: What Is h in Calculus Limits and Tangent Lines?
What is the definition of a limit?
The limit of a function is the value that the function approaches as the input approaches a certain value. It can be thought of as the "end behavior" of a function.
How do you find the limit of a function algebraically?
To find the limit of a function algebraically, you can plug in the value the input is approaching into the function and simplify. If the simplified expression is undefined, you can try factoring or using other algebraic techniques to simplify further.
When is a limit undefined?
A limit is undefined when the function does not approach a specific value as the input approaches a certain value. This can occur when there is a vertical asymptote or a discontinuity in the function.
What is the derivative of a tangent line?
The derivative of a tangent line is the slope of the line at a specific point on a curve. It represents the rate of change of the function at that point.
How do you find the equation of a tangent line?
To find the equation of a tangent line, you can use the point-slope formula and plug in the coordinates of the point of tangency and the derivative of the function at that point. This will give you the equation of the tangent line in the form y = mx + b, where m is the slope and b is the y-intercept.
