- 19,551
- 10,300
Definition/Summary
The half-life, [itex]t_{1/2}[/itex], of an inverse exponential process (an exponential decay) is the time taken for the amount to reduce by one-half. It is constant.
Processes with a half-life include radioactive decay, first-order chemical reactions, and current flowing through an RC electrical circuit.
The half-life divided by the (natural) logarithm of 2 is the mean lifetime, [itex]{\tau}[/itex]. It is the time taken for the amount to reduce by a factor e (ie 2.718...). It is the inverse of the decay constant, [itex]{\lambda}[/itex], also referred to as the decay rate, or probability per unit time of decay.
Equations
Inverse exponential process (exponential decay) with decay constant [itex]\lambda[/itex]:
[tex]A = A_0e^{-\lambda t}[/tex]
Mean lifetime:
[tex]\tau\ =\ \frac{1}{\lambda} \ =\ \frac{t_{1/2}}{\log 2}[/tex]
where [itex]\log[/itex] denotes the natural logarithm.
Half-life:
[tex]t_{1/2}\ =\ \frac{log2}{\lambda} \ = \ \tau\ \log 2 [/tex]
For decay of the same population by two or more simultaneous inverse exponential processes with decay constants [itex]\lambda_1,\cdots,\lambda_n[/itex]:
[tex]\lambda\ =\ \lambda_1\ +\ \cdots\ +\ \lambda_n[/tex]
[tex]\frac{1}{\tau}\ =\ \frac{1}{\tau_1}\ +\ \cdots\ +\ \frac{1}{\tau_n}[/tex]
[tex]\frac{1}{t_{1/2}}\ =\ \frac{1}{\left(t_1\right)_{1/2}}\ +\ \cdots\ +\ \frac{1}{\left(t_n\right)_{1/2}}[/tex]
Extended explanation
Radioactive decay:
The quantity which reduces is the expectation value of the quantity of radioactive material.
RC circuits:
The flow of current discharged from a capacitor through a resistor (an RC circuit) is an inverse exponential process with mean lifetime (time constant) equal to the resistance times the capacitance: [itex]\frac{1}{\lambda}\ =\ \tau\ =\ RC[/itex].
Other meanings:
Technically, a half-life could be defined for any process, at each stage of that process, but it would not be constant …
it is only for an inverse exponential process that the half-life is the same at each stage …
and so it is only for an inverse exponential process that a half-life for a process can be defined.
* This entry is from our old Library feature. If you know who wrote it, please let us know so we can attribute a writer. Thanks!
Equations
Mean lifetime:
Half-life:
Radioactive decay:
RC circuits:
Other meanings:
