What is happning with phase changes and intermolecular forces
In summary, when a substance undergoes a phase change from a solid to a liquid, it can absorb heat energy without undergoing a temperature change. This is because when a substance melts, the atoms absorb energy and vibrate faster, overriding the intermolecular forces. However, temperature is not solely defined as the average kinetic energy of molecules, as demonstrated by the fact that temperature does not increase during a phase change. This suggests that there is more to phase change on a molecular level than just kinetic energy.
kjamha
98
When a substance undergoes a phase change from a solid to a liquid the substance can absorb heat energy without undergoing a temperature change. But I also read that when a substance melts, the atoms absorb energy and thereby vibrate faster, overcoming the intermolecular forces. Temperature is defined as the average KE of random translational motion of atoms/molecules of a substance.
So if molecules vibrate faster in overcoming intermolecular forces, wouldn't the temperature go up? This contradicts the fact that temperature does not go up during a phase change. Can someone shed some light on this? I'm thinking there is a lot more to phase change on a molecular level. Thanks!
No, it is not defined like that. This is just a simple picture of what goes on inside a substance when the temperature changes.
Exactly! The conclusion is that saying that T = KE is incorrect (or incomplete).
Related to What is happning with phase changes and intermolecular forces
What causes phase changes?
Phase changes occur when there is a change in the intermolecular forces between particles. These forces can be affected by temperature, pressure, and the amount of energy present.
How do intermolecular forces impact phase changes?
Intermolecular forces are responsible for holding particles together in a substance. When these forces are weakened or strengthened, it can cause a shift in the phase of the substance, such as from solid to liquid or liquid to gas.
What is the relationship between temperature and phase changes?
Temperature plays a crucial role in phase changes. As temperature increases, the particles in a substance gain more energy and can overcome the intermolecular forces holding them together, resulting in a phase change.
Can intermolecular forces be manipulated to control phase changes?
Yes, intermolecular forces can be manipulated through changes in temperature or pressure to control phase changes. This is commonly seen in industrial processes, such as distillation, where substances are separated based on their different boiling points.
How do phase changes and intermolecular forces impact the properties of a substance?
Phase changes and intermolecular forces play a significant role in determining the physical properties of a substance. For example, a substance with weak intermolecular forces will have a low melting and boiling point, while a substance with strong intermolecular forces will have a high melting and boiling point.
  • Other Physics Topics
  • Quantum Physics
