What is integration of y/(x^2-y^2) dx
In summary: In that case, the solution is a bit more complicated, but I believe this is sufficient: .$\displaystyle \frac{1}{2}\ln\left|y^2-x^2\right|+C$In summary, the conversation discusses the integration of y/(x^2-y^2) dx using partial fraction decomposition and the Heaviside cover-up method. The final solution is 1/2ln(x-y) + -1/2ln(x+y) + c, or alternatively, 1/2ln(y^2-x^2) + C, depending on whether y is treated as a constant or a function of x.
r-soy
172
Hi all
can please explaine to me what is integration of y/(x^2-y^2) dx
step by step ...
Re: what is integration of y/(x^2-y^2) dx
Hey Ahmed :
I think you have already studied partial fraction decomposition when you learned about integration .
Here we can treat y as constant hence, we don't need to worry about it , because we are integrating w.r.t x ...
we know by the difference of two squares that :
\(\displaystyle x^2-y^2=(x-y)(x+y)\)
\(\displaystyle \frac{y}{(x-y)(x+y)}=\frac{A}{x-y}+\frac{B}{x+y}\)
Hence we have the following :
\(\displaystyle y = A(x+y) + B(x-y) \)
Now we need to find both A and B so do the following :
1- put x= y so the equation becomes :
\(\displaystyle y = 2y\, A\) , \(\displaystyle A =\frac{1}{2}\)
2-To find B we put x=-y
\(\displaystyle y = -2y \,B \) , \(\displaystyle B =\frac{-1}{2}\)
\(\displaystyle \frac{y}{(x-y)(x+y)}=\frac{\frac{1}{2}}{x-y}+\frac{\frac{-1}{2}}{x+y}\)
Now can you integrate the right hand side ?
1/2ln(x-y) + -1/2(x+y)
rsoy said:
Hi all
step by step ...
Did you check out the Heaviside cover-up method I pointed you to the other day for partial fraction decomposition?
No, this isn't correct , you are missing an absolute value and a ln in the second part !
Also , don't forget that there should be a constant which is a function of y ...
- - - Updated - - -
Yes
Still , you are missing the absolute value , also C here is a function of y it is is usually wirtten \(\displaystyle \phi(y)\)
rsoy said:
Hi all
step by step ...
Has this question come from trying to solve a differential equation, which would make y a function of x? Or are you doing a "partial integral", in other words, holding y constant while trying to integrate with respect to x?
rsoy said:
Hi all
step by step ...
Another approach.
If you have a list of derivatives of trigonometric hyperbolic functions, you should have:
$$\frac{d}{dx} \text{ artanh } x = \frac 1 {1-x^2}$$
I like Serena said:
Another approach.
If you have a list of derivatives of trigonometric functions, you should have:
Hyperbolic functions...
Hello, rsoy!
$\displaystyle\int \frac{y}{x^2-y^2}\,dx$
Since $y$ is treated as a constant $b$, we have: .$\displaystyle b\int\frac{dx}{x^2-b^2}$There is a standard integration formula: .$\displaystyle \int \frac{du}{u^2-a^2} \:=\:\frac{1}{2a}\ln\left|\frac{u-a}{u+a}\right|+C $Therefore: .$\displaystyle b\left(\frac{1}{2b}\right)\ln\left|\frac{x-b}{x+b}\right|+C \;=\;\frac{1}{2}\ln\left|\frac{x-y}{x+y}\right|+C$
soroban said:
Hello, rsoy!
The OP has not specified if this is actually the case...
I believe your earlier suspicion that this arose in the process of solving an ODE was correct, i.e., that $y$ is actually dependent upon $x$.
FAQ: What is integration of y/(x^2-y^2) dx
What is integration of y/(x^2-y^2) dx?
The integration of y/(x^2-y^2) dx is a mathematical process that involves finding the antiderivative of the given function, which is the function that, when differentiated, gives the original function. It is commonly used in calculus and other areas of mathematics.
How do you solve the integration of y/(x^2-y^2) dx?
To solve the integration of y/(x^2-y^2) dx, you can use the method of partial fractions, where the given function is broken down into simpler fractions that can be integrated separately. Another method is to use the substitution method, where you substitute a new variable for the given function to simplify the integration process.
What is the purpose of solving the integration of y/(x^2-y^2) dx?
The purpose of solving the integration of y/(x^2-y^2) dx is to be able to find the area under the curve of the given function. This can be useful in various real-world applications, such as calculating the work done by a force or determining the volume of irregular shapes.
What are the common mistakes when solving the integration of y/(x^2-y^2) dx?
Common mistakes when solving the integration of y/(x^2-y^2) dx include forgetting to use the chain rule, not correctly simplifying the fractions, and making errors in algebraic manipulation. It is important to double-check your work and use proper techniques to avoid these mistakes.
Are there any tips for solving the integration of y/(x^2-y^2) dx?
Some tips for solving the integration of y/(x^2-y^2) dx include practicing with different examples, being familiar with the properties of logarithmic and exponential functions, and using a table of integrals for commonly encountered functions. It is also helpful to break down the given function into simpler fractions before attempting to integrate.
