How Does L'Hôpital's Rule Solve Indeterminate Forms in Calculus?
In summary, l'Hôpital's rule is a method for finding the limit of a function with an indeterminate form. It states that if the ratio of the limits of the derivatives of two functions has the form 0/0 or \infty / \infty, then the limit of the original ratio can be found by taking the limit of the derivatives. This rule can be applied multiple times if necessary, but it may not always help in finding the limit. It is also applicable to improper interval limits.
10,300
Definition/Summary
L'Hôpital's (or l'Hospital's) rule is a method for finding the limit of a function with an indeterminate form.
Equations
If the expression
[tex]\frac{\lim_{x \rightarrow a} f(x)}{\lim_{x \rightarrow a} g(x)}[/tex]
has the form [itex]0/0[/itex] or [itex]\infty / \infty[/itex], then l'Hôpital's rule states that
[tex]\lim_{x \rightarrow a} \frac{f(x)}{g(x)}
= \lim_{x \rightarrow a} \frac{f'(x)}{g'(x)}[/tex]
provided that that second limit exists.
Extended explanation
Examples:
[tex]1.~~\lim_{x\rightarrow 0}\frac{\sin x}{x}\,=\,\lim_{x\rightarrow 0}\frac{\cos x}{1}\,=\,1[/tex]
[tex]2.~~\lim_{x\rightarrow 0}\frac{e^x-1}{x}\,=\,\lim_{x\rightarrow 0}\frac{e^x}{1}\,=\,1[/tex]
The rule can be applied more than once:
If after one application, the ratio is still of the form [itex]0/0[/itex] or [itex]\infty / \infty[/itex], then the rule may be applied again (and as many times as are needed to produce a limit):
[tex]3.~~\lim_{x\rightarrow 0}\frac{e^x\,-\,x\,-1}{\frac{1}{2}x^2}\,=\,\lim_{x\rightarrow 0}\frac{e^x\,-\,1}{x}\,=\,\lim_{x\rightarrow 0}\frac{e^x}{1}\,=\,1[/tex]
Example of the rule not helping:
It is possible that the limit of the ratio of the derivatives does not exist, even though the limit of the original ratio does:
[tex]\lim_{x\rightarrow \infty}\frac{x\ +\ \sin x}{x}\ =\ 1[/tex]
but [tex]\lim_{x\rightarrow \infty}\frac{1 +\ \cos x}{1}[/tex] does not exist.
* This entry is from our old Library feature. If you know who wrote it, please let us know so we can attribute a writer. Thanks!
Mathematics news on Phys.org
The exact wording is:
Be ##I = ({\tilde{x}}_{0}, x_{0})## a non-empty open interval and are ##f, \, g \colon I \to \mathbb{R}## differentiable functions for ##x \nearrow x_{0}## (##x## goes from below against ##x_{0}##) both converge to ##0## or both diverge definitely.
If ##g'(x) \neq 0## for all ##x \in I## holds and ##\tfrac{f\,'(x)}{g' (x)}## for ##x \nearrow x_{0}## converges against a value ##q## or definitely diverges, so does ##\tfrac{f (x)}{g (x)}##. The same applies if we switch to ##x \searrow x_{0}## everywhere (##x## goes from above against ##\tilde{x}_{0}).##
Is ##I## a true subset of an open interval, on which the conditions are met, we have in particular
\lim_{x \to x_{0}} \frac{f\,'(x)}{g' (x)} = q ~ \Longrightarrow ~ \lim_{x \to x_{0} } \frac{f (x)}{g (x)} = q
The theorem also applies to improper interval limits ##x_{0} = \pm \infty \,.##
FAQ: How Does L'Hôpital's Rule Solve Indeterminate Forms in Calculus?
1. What is l'Hôpital's rule?
L'Hôpital's rule is a mathematical theorem used to evaluate limits involving indeterminate forms such as 0/0 and ∞/∞. It states that the limit of the ratio of two functions is equal to the limit of the ratio of their derivatives, under certain conditions.
2. Who discovered l'Hôpital's rule?
L'Hôpital's rule was discovered by the mathematician Guillaume de l'Hôpital in the 17th century. However, it is believed that the rule was actually discovered by Johann Bernoulli, who taught it to l'Hôpital and urged him to publish it under his name.
3. How is l'Hôpital's rule applied?
L'Hôpital's rule is applied when evaluating limits that result in indeterminate forms. To use the rule, both the numerator and denominator of the limit must be in the form of a function. Then, the derivatives of both functions are taken and the limit is recalculated using these derivatives.
4. What are the conditions for using l'Hôpital's rule?
The conditions for using l'Hôpital's rule are that the limit must be in indeterminate form, and the functions in the numerator and denominator must be differentiable in a neighborhood of the limit point.
5. Why is l'Hôpital's rule important?
L'Hôpital's rule is important because it provides a method for evaluating limits involving indeterminate forms that cannot be solved using basic algebraic techniques. It is also a useful tool for solving a variety of problems in calculus, such as finding the maximum and minimum values of a function.
