What is lim_(n→∞) ∫_(-∞)^∞〖〖 x〗^n e^(-n|x|) dm 〗?
  • MHB
  • Thread starter Jack3
In summary, we have an integral with a limit as n tends to infinity. Using substitution and the Gamma function, we can simplify the integral and solve for the limit. The limit is equal to zero and can be proven using mathematical methods.
Jack3
Find the limit and prove your answer.
Re: What is lim_(n→∞) ∫_(-∞)^∞〖〖 x〗^n e^(-n|x|) dm 〗?
Hi Jack, :)
I suggest you should learn some LaTeX before posting questions since the characters that you use makes it difficult to understand what your question is. We have a nice http://www.mathhelpboards.com/f26/ that you can use to learn LaTeX.
Is this your integral?
\[\lim_{n\rightarrow\infty}\int_{-\infty}^{\infty}\left|x\right|^{n} e^{-n|x|}\,dx\]
Kind Regards,
Sudharaka.
Sudharaka said:
Hi Jack, :)
Kind Regards,
Sudharaka.
YEs。
\[\int_{-\infty}^{\infty}\left|x\right|^{n} e^{-n|x|}\,dx=2\int_{0}^{\infty}x^{n} e^{-nx}\,dx\]
Substitute \(y=nx\) and we get,
\begin{eqnarray}
\int_{-\infty}^{\infty}\left|x\right|^{n} e^{-n|x|}\,dx&=&\frac{2}{n^{n+1}}\int_{0}^{\infty}y^{n} e^{-y}\,dy\\
&=&\frac{2}{n^{n+1}}\Gamma(n+1)
\end{eqnarray}
I am assuming that \(n\) is a positive integer. Then,
\[\int_{-\infty}^{\infty}\left|x\right|^{n} e^{-n|x|}\,dx=\frac{2\Gamma(n+1)}{n^{n+1}}=\frac{2n!}{n^{n+1}}\]
It could be shown that, \(\displaystyle\lim_{n\rightarrow \infty}\frac{2n!}{n^{n+1}}=0\).
\[\therefore \lim_{n\rightarrow \infty}\int_{-\infty}^{\infty}\left|x\right|^{n} e^{-n|x|}\,dx=\lim_{n\rightarrow \infty}\frac{2n!}{n^{n+1}}=0\]
The limit in question is a well-known integral in mathematics known as the Laplace transform. This integral is often used in the study of differential equations and has important applications in physics and engineering.
As n approaches infinity, the exponential term e^(-n|x|) will become smaller and smaller, approaching 0. This means that the integral will primarily be determined by the term x^n, which increases without bound as n approaches infinity.
To prove this, we can use the Dominated Convergence Theorem, which states that if a sequence of functions f_n converges pointwise to a function f and if there exists a function g such that g is integrable and |f_n(x)| ≤ g(x) for all x, then the integral of f_n converges to the integral of f.
In this case, we can choose g(x) = x^n, which is integrable over the entire real line. We can also see that |f_n(x)| ≤ g(x) for all x, since the exponential term will eventually become negligible as n approaches infinity. Therefore, by the Dominated Convergence Theorem, we can conclude that the limit of the integral is equal to the integral of the limit, which is just the integral of x^n.
As n approaches infinity, the integral of x^n will diverge, meaning that there is no finite limit for this integral. In other words, the limit of the original integral is equal to infinity.
In conclusion, lim_(n→∞) ∫_(-∞)^∞〖〖 x〗^n e^(-n|x|) dm 〗 is equal to infinity. This result is important in the study of Laplace transforms and has many practical applications in fields such as engineering and physics.
FAQ: What is lim_(n→∞) ∫_(-∞)^∞〖〖 x〗^n e^(-n|x|) dm 〗?
What does the notation lim_(n→∞) mean in this expression?
The notation lim_(n→∞) represents the limit as n approaches infinity. In this expression, it is used to indicate that the value of the integral will approach a certain value as n gets larger and larger.
What does the integral of this expression represent?
The integral represents the area under the curve of the function x^n e^(-n|x|) from -∞ to ∞. In this case, the function is decaying exponentially and the integral represents the total area under this decay.
How does the value of n affect the integral?
The value of n affects the shape of the function and therefore, the overall area under the curve. As n increases, the function decays more quickly, resulting in a smaller integral value.
How does the value of the integral change as n gets larger?
As n gets larger, the value of the integral approaches 0. This is because the exponential decay of the function becomes more and more significant, resulting in a smaller and smaller area under the curve.
What is the significance of taking the limit as n approaches infinity?
Taking the limit as n approaches infinity allows us to see the behavior of the integral as the function approaches its maximum decay. It tells us what the final, overall area under the curve will be and how it changes as n gets larger and larger.
