What is mass of particle X before the decay?
In summary, Professor X has discovered a new particle, particle X, using her new detector called The da Vinci Decoder. This particle violates lepton number conservation and is observed to decay into an alpha particle, a proton, an electron, and a neutrino. The total kinetic energy of these decay products is 9.819 × 10−13 J, and using the equations k=1/2mv^2 and Erest=mc^2, the mass of particle X is calculated to be 2.465E-8 kg. However, this value may be slightly more than the actual mass of particle X due to the neglect of the neutrino and the binding energy of the decay products.
Westin
87
Professor X, a nuclear physicist who works at the MSU FRIB facility, has designed a new particle detector called The da Vinci Decoder. Using this detector, she has discovered a new particle dubbed particle X that violates lepton number conservation. A stationary X is observed to decay spontaneously into an alpha particle (α) plus a proton (p), electron (e), and a neutrino (ν):
X − −−→ α + p + e + ν .
The mass of an alpha particle is 4.00260u (this is the rest mass, which accounts for binding energy), the mass of a proton is 1.00727u, and the mass of an electron is 0.000 55 u. Lastly, the mass of a neutrino is less than one billionth of an atomic mass unit – in other words you can neglect its mass.
(a) After the decay, the alpha, proton, electron, and neutrino, are all mov- ing in different directions, with a total kinetic energy Ktot = 9.819 × 10−13 J = 6.128 MeV. What is the mass of the X particle?
k=1/2mv^2
Erest=mc^2
p= mv/(sqrt(1-(v/c)^2))
Add up the velocities of the particles
6.128MeV=1/2(4.0026)v
alpha particle v= 3.062m/s
6.128MeV=1/2(1.00727)v
proton particle v= 12.168m/s
6.128MeV=1/2(.00055)v
electron particle v= 22283.636m/s
v1+v2+v3 = 22298.866m/s
Now use k=1/2mv^2 to find mass of particle X
6.128 MeV = (1/2)m(22298.866m/s)^2
2.465E-8 kg
This answer is obviously way off, it should be a little more than the total masses given because of the binding energy in particle X.
Please help put me on the right track.
[/B]
The reaction is
X --> alpha + p + e (+ v, but we neglect) + Kinetic Energy
If this is the case, then X should have the mass of the alpha+p+e+KE, slightly more than the mass of the constituents.
For a contrasting situation (where a decay mode is forbidden because it weighs less than the would-be products), see here --> http://hyperphysics.phy-astr.gsu.edu/hbase/particles/deuteron.html
Related to What is mass of particle X before the decay?
1. What is mass of particle X before the decay?
The mass of particle X before decay can vary depending on the specific particle and its decay process. However, the mass is typically measured in units of kilograms (kg) or electron volts (eV).
2. How is the mass of particle X determined before decay?
The mass of particle X is usually determined through experiments using particle accelerators, where scientists observe and measure the particles' behavior and interactions. The mass can also be calculated using mathematical equations based on the particles' properties and interactions.
3. Can the mass of particle X change before decay?
Yes, the mass of particle X can change before decay due to interactions with other particles or through the decay process itself. This change in mass is known as mass-energy equivalence, as described by Einstein's famous equation E=mc^2.
4. How does the mass of particle X affect its decay?
The mass of particle X can affect its decay in several ways. For example, a higher mass may result in a longer decay time, while a lower mass may cause the particle to decay more quickly. The mass can also determine what particles the particle X can decay into.
5. Is there a limit to the mass of particle X before decay?
There is no known limit to the mass of particle X before decay. However, as the mass increases, the particle may become more unstable and more likely to decay. Additionally, the mass of particle X may reach a certain point where it is too heavy to be considered a particle and is instead classified as a black hole.
