What is meant by compex dimension? (Abstract algebra)
Ineedhelpimbadatphys
Show that the set of n:th order complex polynomials
Pn ≡{a0 +a1z+a2z2 +···+anzn|a0,a1,...,an ∈Cn}
is a vector space. What is its (complex) dimension?
picture since the text is a little hard to read
i have no problem showing this is a vector space, but what is meant by complex dimention?
Is it just the number on independant complex numbers, so n?
Do you know how the dimension of a vector space is defined? It involves linear (in-)dependency and therefore the underlying scalar field. E.g. ##\mathbb{C}\cdot [\vec{1}]## is a complex line, hence one-dimensional. But if we consider ##[\vec{1}]## as a real vector, what is the dimension of ##\mathbb{R}\cdot [\vec{1}]##?
There are two independant scalars in a complex number. So does that mean 2n.
Sorry, this was supposed to be a reply. Im really not understanding the subject so sorry for simple questions.
No. It only means ##2n## over the reals! It is still ##n## over the complex numbers.
If we write a complex number ##a+\mathrm{i} b## as real vector ##(a,b)## then we get
\dim_\mathbb{R} \left\{\mathbb{R}\cdot\begin{pmatrix}a\\0\end{pmatrix}\oplus \mathbb{R}\cdot\begin{pmatrix}0\\b\end{pmatrix}\right\}=2\, , \,\dim_\mathbb{R} \mathbb{R}\cdot\begin{pmatrix}a\\b\end{pmatrix}=1
and
\dim_\mathbb{C} \left\{\mathbb{C}\cdot a + \mathbb{C}\cdot \mathrm{i}b\right\}=1\, , \,\dim_\mathbb{C} \mathbb{C}\cdot (a+\mathrm{i}b) =1
I assume the exercise was to understand this difference. The field is essential here.
Likes FactChecker
The dimension is ##n+1##.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
