What is "Modern Quantum Simulation" experimentation?
In summary, the conversation discusses the concept of quantum simulation, which is the use of controllable systems to simulate the behavior of complex quantum systems. This can be done through creating a mathematically equivalent system, similar to the use of analogue computers in the past. This allows for the study of quantum systems that are difficult or impossible to access in practice. It is not limited to quantum computers or processes, but can also be applied to simpler physical systems. The reliability of this method is dependent on the accuracy of the mapping between the simulated and actual system.
Gerinski
323
Hi all,
In this paper they mention that the "experiments" were done using "quantum simulation". Expressions like the following are used:
"Here we experimentally simulate the nonlinear behaviour of a qubit..."
"Modern experimental quantum simulation allows one to ask meaningful questions that provide insights into the behaviour of complex quantum systems"
"Our experimental simulation of a qubit in the pure state..."
"Quantum simulation is a versatile and powerful tool for investigating quantum systems that are hard or even impossible to access in practice"
http://www.nature.com/articles/ncom...&tracking_referrer=www.scientificamerican.com
What is such a "quantum simulation experiment"? Is it a real physical experiment? Or a computer simulated one? How can be quantum behaviour simulated not using a quantum computer or quantum process? Is it about modelling, or mapping, a complex quantum process into some simpler physical quantum system such as studying photons polarization behaviour? If so, how confident can we be that such simple models provide a reliable mapping for the way more complex systems behave?
TX
The principle is very similar to an analogue computer. Before digital computers became commonplace analogue computers were (and in some cases still are) used in many applications that requires fast solution of mathematical problems (in.e.g. control system for aircraft). The idea is to create one system that is mathematically equivalent to another. The most common case was to create analogue electrical circuits (using capacitors, inductors etc) that were arranged in such a way that the differential equations that governed their behaviors were identical to the behavior of some mechanical system you wanted to simulate.
Quantum simulators work in the same way. The idea is to create a "simple" controllable system that is mathematically identical (in the simplest case it might have the same effective Hamiltonian) to some other more complicated (and not easily controlled) system you want to simulate.
Related to What is "Modern Quantum Simulation" experimentation?
1. What is quantum simulation?
Quantum simulation is a method used to model and study complex quantum systems that are difficult to analyze using traditional mathematical or experimental techniques. It involves using controlled quantum systems to simulate the behavior of a more complex quantum system, providing valuable insights into its properties and behavior.
2. How does quantum simulation differ from traditional simulation methods?
Traditional simulation methods use classical computers to model and predict the behavior of physical systems. Quantum simulation, on the other hand, uses quantum computers or specialized quantum simulators to model and analyze quantum systems, which allows for more accurate and detailed simulations of complex quantum phenomena.
3. What are the potential applications of modern quantum simulation?
Modern quantum simulation has a wide range of potential applications, including studying and designing new materials, optimizing chemical reactions, and developing new pharmaceuticals. It also has potential applications in fields such as finance, cryptography, and machine learning.
4. How does modern quantum simulation work?
Modern quantum simulation works by creating a controlled quantum system that can accurately mimic the behavior of a more complex quantum system. This involves encoding the properties of the system into the quantum computer or simulator, manipulating the quantum states, and measuring the resulting outputs to gain insights into the system's behavior.
5. What are the challenges of conducting quantum simulation experiments?
Some of the main challenges of conducting quantum simulation experiments include controlling and maintaining the fragile quantum states, minimizing errors and decoherence, and scaling up the simulations to larger and more complex systems. Additionally, the cost and availability of quantum computers and specialized simulators can also be a limiting factor.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Computing and Technology
