What is noted by +_5 in measuring cylinder?
In summary, the "+/- 5" on a measuring cylinder represents the margin of error in the measurement and can affect the accuracy of the measurement. It should not be ignored when measuring small volumes and if the measurement falls between two markings, it is best to estimate to the nearest tenth or hundredth. To improve the accuracy, a cylinder with a smaller margin of error can be used and multiple measurements can be taken and averaged.
abi.ayan
37
can anyone explain why is that noted?Most of them says that it denotes the error.why there should be an error in the instrument.Can't we make an instrument free of error?confused.
Chemistry news on Phys.org
No..
How accurately can the practical, graduated, vertical number line be read? Free of Error is impossible.
FAQ: What is noted by +_5 in measuring cylinder?
What does the "+/- 5" mean on a measuring cylinder?
The "+/- 5" on a measuring cylinder refers to the margin of error in the measurement. This means that the measurement may vary by up to 5 units in either direction from the marked measurement on the cylinder.
How does the "+/- 5" affect the accuracy of the measurement?
The "+/- 5" indicates the precision of the measurement. This means that the actual value may be within 5 units of the marked measurement on the cylinder. Therefore, the larger the "+/-" value, the less accurate the measurement will be.
Can the "+/- 5" be ignored when measuring small volumes?
No, the "+/- 5" should not be ignored regardless of the volume being measured. Even when measuring small volumes, the margin of error can still affect the accuracy of the measurement.
What should be done if the measurement falls between two markings on the cylinder?
If the measurement falls between two markings on the cylinder, it is best to estimate to the nearest tenth or hundredth, depending on the precision of the cylinder. For example, if the cylinder is marked in milliliters, estimate to the nearest tenth, and if it is marked in microliters, estimate to the nearest hundredth.
How can the measurement accuracy be improved when using a measuring cylinder with a "+/- 5" margin of error?
The accuracy of the measurement can be improved by using a cylinder with a smaller margin of error, such as a "+/- 2" or "+/- 1" cylinder. Additionally, taking multiple measurements and calculating the average can also improve the accuracy.
