- #36
- 23,364
- 5,731
You don't need to have a wall to have pressure. Now you have two Mentors telling you this.
Imagine that you have a thin rigid barrier between the two sides of a compartment, and a gas at the same pressure on both sides. Molecules on each side of the barrier bounce off the barrier and impose a momentum flux on each side of the barrier (which is interpreted as a force). Now, remove the barrier, and replace it with an imaginary plane. In this case, there are no molecules bouncing off of each side, but now there is a momentum flux on each side from molecules passing through the plane from the other side. So the effect is exactly the same as if there were a real solid barrier present. The molecules passing through the plane are not bouncing off the plane, but there are molecules passing through the plane from the other side just as if they had; it's just that they are not the exact same molecules. Otherwise, everything is exactly the same.
In the case of a liquid, the picture is even more compelling because the molecules on the two sides of the plane are actually touching each other.
