What Is Radiant Exitance?
  • Thread starter linsnos
In summary, the power per surface area resulting from diffuse reflection is called "diffuse reflectance" or "diffuse reflectivity." The process of electrons being excited by incoming light is called "photoexcitation," and the term "exitance" refers to the total amount of light leaving a surface. Best wishes!
radiant excitance or radiant exitance?
  • excitance
    Votes: 1 100.0%
  • exitance
    Votes: 0 0.0%
  • Total voters
linsnos
Hi!
The power per surface area as a result of diffuse reflection of incoming light, what is it called?
The electrons are excited by the incoming light and when returning to their ground states they emit the light we perceive as diffuse reflected.
Is it the "leaving" which become "exit", or is it the "excitation" which become "excit"?
/Best wishes!
Edit: Well, I suppose the correct one is "exitance", since that is what they use in my book about introductory optics. The word could then be explained as "leaving along a ray" or something similar, which is all right to me! :D
Hello,
Thank you for your post! The power per surface area resulting from diffuse reflection of incoming light is called "diffuse reflectance" or "diffuse reflectivity." This refers to the amount of light that is reflected in all directions from a surface, as opposed to being reflected in a single direction (known as specular reflection).
In terms of the electrons being excited by the incoming light, the process is called "photoexcitation." This is when the energy from the incoming light is absorbed by the electrons, causing them to jump to a higher energy level. When they return to their ground state, they emit light, which is known as "fluorescence" or "phosphorescence" depending on the length of time the electrons stay in the excited state.
The term "exitance" refers to the total amount of light leaving a surface, including both reflected and emitted light. It is a measure of the total light output from a surface and is often used in radiometry and photometry.
I hope this helps clarify the terminology for you! Best wishes to you as well.
Hello there! It's great that you are learning about optics and asking questions about the terminology. Exitance or excitance refers to the amount of radiant flux (power) per unit area that is emitted, transmitted, or reflected from a surface. In the case of diffuse reflection, it is the power per unit area resulting from the diffuse reflection of incoming light.
To answer your question, it is the "excitation" that becomes "excit" in excitance. This term comes from the fact that when light hits a surface, it excites the electrons in the material, causing them to move to higher energy levels. When they return to their ground states, they emit light, which we perceive as diffuse reflected light.
I'm glad you mentioned that your book uses the term "exitance" because that is the correct term for this concept. It can be thought of as the "leaving" of light from a surface along a ray. Keep up the curiosity and good luck with your studies!
FAQ: What Is Radiant Exitance?
What is exitance or excitance?
Exitance or excitance is a measure of the radiant flux emitted or reflected by a surface, per unit area, and per unit solid angle. It is commonly represented by the symbol M or E, and has units of watts per square meter per steradian (W/m^2/sr).
How is exitance or excitance different from irradiance?
Exitance or excitance is similar to irradiance, but it takes into account the direction of the radiant flux. Irradiance is a measure of the total amount of radiant flux incident on a surface, regardless of direction. It is commonly represented by the symbol E, and has units of watts per square meter (W/m^2).
What factors affect the exitance or excitance of a surface?
The exitance or excitance of a surface is affected by several factors, including the spectral distribution of the incident radiation, the reflectivity of the surface, and the angle of incidence of the radiation. It also depends on the surface's temperature, as hotter surfaces emit more radiant flux.
How is exitance or excitance measured?
Exitance or excitance can be measured using instruments such as radiometers or spectroradiometers. These devices are calibrated to measure the amount of radiant flux within a certain wavelength range and direction. The measurement is typically taken in watts per square meter per steradian (W/m^2/sr).
What are the applications of exitance or excitance in science?
Exitance or excitance is an important concept in many fields of science, including physics, astronomy, and engineering. It is used to characterize the emission and reflection of radiation from various surfaces, and is crucial for understanding phenomena such as heat transfer, solar radiation, and remote sensing. It is also used in the development of technologies such as solar panels and thermal imaging devices.
