MHB What Is Required to Prove a Subset is a Vector Space?
Yankel
Hello all,
I have a theoretical question regarding subspaces.
If V is a subset of a vector space, and we wish to show that V is a vector space itself, we need to show 3 things.
Some references say we need to show: a) V is not empty b) V is closed under + c) V is closed under scalar multiplication. Other references are similar, with (a) being that V contains the 0 vector in it.
What I don't understand is:
1) Why being non empty and having the 0 vector is the same thing ?
2) I can't think of any example in which a set is closed under + and scalar multiplication, but does not contain the 0 vector. If this case exist, it ain't a subspace, but if the set isn't empty, it is ??
I am confused...
Yankel said:
Hello all,
I am confused...
ad 1) I understand that you assume b) and c) and then want to show that the two formulations of condition a) are equivalent.
If $V$ is non-empty, then it contains a vector $x$. Now $V$ is closed under scalar multiplication, so $0\cdot x = \mathbf{0} \in V$, where $0$ is a scalar and $\mathbf{0}$ is the zero vector.
Conversely, if $V$ contains $\mathbf{0}$ then it is of course non-empty.
ad 2) You are right, the only such example would be the empty set: It is trivially closed under vector addition and scalar multiplication, but it does not contain the zero vector.
"Being non-empty" and "containing the 0 vector" are not the same thing, alone! However, with the other condirion, that the set is closed under scalar multiplication, they are.
Clearly, if a set "contains the 0 vector" then it "is non-empty" so that way is trivial. If a set "is non-empty" then it contains some, possibly non-zero, vector v. If the set is also "closed under scalar multiplication", then the set also contains 0(v)= 0, the 0 vector.
Thank you both.
Great explanations, all clear now ! :D
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
