What is responsible for the spinning of a galaxy?
In summary, the rotation of the Earth can influence the direction of water swirls, but it is not the main reason for their formation. Similarly, the angular momentum of gas clouds during star formation is responsible for the rotation of galaxies. In intergalactic space, gravitational forces can cause stars to orbit in a particular direction, with the star with the most angular momentum determining the overall direction of the system.
MikeeMiracle
398
313
TL;DR Summary
If you fill a sink with water and then let it drain, the water swirls due to the rotation of the Earth influencing it. During star formation, the primordial accredisk disk spins due to it's galaxy's rotation as I understand it.
This being the case, what force made / makes the galaxy spin to begin with?
Likewise, if say a small galaxy passes through a circular galaxy, what makes the captured stars start following in the same direction as the existing stars in the galaxy?
I am assuming that the stars orbit in a plane similar to the "equator" of the black hold in the center in the same way the planets orbit the stars?
Astronomy news on Phys.org
This is not entirely accurate. There is a Coriolis effect that can be observed on meter scale bodies, but in the typical situation, the Coriolis effect is not the main reason for a swirl to form in a particular direction. Unless you let the water settle for a long time, it is typically much more important how the water is poured into the drain, i.e., a pre-existing angular momentum leading to clear swirl once the water comes closer to the drain.
Same as the water drain. Galaxies will typically not form with zero angular momentum. As the gas cloud forming the galaxies contracts, conservation of angular momentum means that there will be a clear rotation with faster speeds (compare to a skater increasing rotational speed when pulling in the arms).
No. There will be some motion in the water before it goes down the drain. Water with no circulation will tend to drop into the drain readily. Water that is turning in the sink will tend to stay towards the sides and will stay in the sink until it either "overflows" into the drain or looses some of its speed (through friction).
Similarly, as parts of the galaxy are pulled together by gravity, they start with motion relative to each other - giving the galaxy as a whole angular momentum.
Ok, I think i get it.
So let's say we have a wondering black hole in intergalactic space and 2 wondering stars. Both stars are attracted by the black hole, one coming in from the "east" and one from the"west." The one with the most angular momentum will determine the direction of the eventual combined system and both stars will spin in that direction eventually once they have settle down into regular orbits?
Does that sound correct?
It's correct in spirit, in the sense that you have grasped the idea, even if the path that got you there has a few errors.
Thank you for the answers
Related to What is responsible for the spinning of a galaxy?
1. What is the main force responsible for the spinning of a galaxy?
The main force responsible for the spinning of a galaxy is gravity. The gravitational pull between stars and other objects within the galaxy causes them to orbit around a central point, resulting in the rotation of the entire galaxy.
2. How does the shape of a galaxy affect its spinning?
The shape of a galaxy can affect its spinning in two ways. First, the distribution of mass within the galaxy can impact the strength of its gravitational pull, which in turn affects the speed of rotation. Second, the shape of the galaxy can also determine the direction of its spin, with some galaxies rotating in a clockwise direction and others in a counterclockwise direction.
3. Can the spinning of a galaxy change over time?
Yes, the spinning of a galaxy can change over time. As galaxies interact and merge with one another, their gravitational forces can cause them to spin faster or slower. Additionally, the distribution of mass within a galaxy can also change, altering its rotation speed.
4. Are there any other factors that contribute to the spinning of a galaxy?
Yes, there are other factors that contribute to the spinning of a galaxy. The presence of dark matter, a mysterious substance that makes up a large portion of a galaxy's mass, also plays a role in its rotation. The distribution of dark matter can affect the gravitational pull and overall rotation of a galaxy.
5. Is the spinning of a galaxy uniform or does it vary across different parts?
The spinning of a galaxy is not uniform and can vary across different parts. The outer regions of a galaxy, where there is less mass, tend to rotate slower compared to the inner regions, where there is more mass. This difference in rotation speed is known as differential rotation and is a common phenomenon in many galaxies.
  • Astronomy and Astrophysics
