What is sin(1) , not sin(10) and not sin(1c) ?
  • Thread starter phymatter
In summary, the sine of an angle is the ratio of the length of the opposite side to the length of the hypotenuse. Sin(1) refers to the sine function with an angle of 1 radian, and its value is approximately 0.8414709848078965. The argument in the sine function is not an angle, but a number without units, although we often associate it with the unit radian for convenience. There are other ways of defining the sine and cosine functions, but they are all ultimately based on the unit circle and the relationship between the opposite and hypotenuse sides.
phymatter
131
what is sin(1) , not sin(10) and not sin(1c) ?
Mathematics news on Phys.org
The sine of an angle is the ratio of the length of the opposite side to the length of the hypotenuse.
sin(1) would be that ratio for a right-sided triangle where the angle is "1". Since you didn't define what an angle of "1" is supposed to mean (other than rejecting existing measures of angle), I won't either.
Actually , here by sin (1) , i mean 1 is a natural number , actually I want to know about the validity of this term : sin (1) , where 1 is a natural number .
To add to axlm's post:
It is meaningless to ask what sin(1) is, unless you specify the angular measure.
If you say, for example, that "1" is the angular measure where the full circle is given the value "4", then sin(1)=1.
Note therefore, that the sine "function" itself, regarded as a function from the real numbers onto itself, is actually a FAMILY OF FUNCTIONS, where each member of that family is a proper function with respect to a particular choice of angular measure.
When "x" is measured as "degrees", sin(x) is a DIFFERENT function than when "x" is measured in radians.
I disagree with Arildno's statement (I've become braver about that sort of thing!) that "It is meaningless to ask what sin(1) is, unless you specify the angular measure."
Sine and cosine, as defined in higher mathematics (there is another thread here on exactly that question) have nothing to do with angles or triangles- they are simply functions and, like all mathematical functions, their arguments are simply numbers.
Look at what I gave, in that other thread, as a definition of sine and cosine:
"Draw a unit circle on a coordinate system. For non-negative t, start at (1, 0) on the circumference of the circle and measure counter clockwise around the circumference of the circle a distance t. The point at which we end has coordinates, by definition, (cos(t), sin(t))." (If t is negative, measure clockwise.) When I say "by definition" I mean that is the definition of sine and cosine: what ever that point is, the first coordinates is cos(t), the second sin(t).
Notice that t, here, is not a an angle at all! It is a distance measured around the unit circle! Of course, calculators are designed by engineers and engineers tend to think of sine and cosine in terms of angles (You will see the phrase "phase angle" in statements about electrical circuits that have no angles at all!) so they "create" an angle measure to fit: radian measure. Any time you see sine or cosine without any angle units indicated, or, for that matter, any time you see trig functions in problems where there are no angles or triangles, the argument is to be interpreted in "radians".
sin(1)= sin(1 radian)= 0.8414709848078965066525023216303, approximately.
Again, the argument, t, in sin(t), is not an angle at all, it is a number with no units. But to keep our engineer friend happy, we say "radians".
Well, I can live with that disagreement, HallsofIvy!
Personally, I would regard the mapping (sin(t),cos(t)) onto the circle as not fully defined until you specify precisely how an interval on the "t"-line maps onto the circle.
(For example, specify how far on the "t"-line you've come when you have made a full circle)
Without that, the definition is fairly under-nourished on "meaning", if not wholly starving..
This is a bit confusing , I clearly understand that we can define sine function by a unit circle but by this do you mean that "Radian is a natural number" !
Radian is the natural number 1, just like percent is the rational number 0.01 and degree is the real number pi/180.
A measurement in radians is unitless. We may obtain it as a ratio of two lengths (arc around a circle divided by radius of circle) for example.
Well, that's not at all what I said! And I did not use the phrase "natural number"- certainly not in what phymatter quoted. I said, just as g edgar did, that it is a number without units.
f(x)= sin(x) requires no units just as g(x)= x2 does not. Strictly speaking the "1" in sin(1) has no units at all- but to keep our engineer friends happy, we can associate that with the angle "1 radian".
Arildno, there are other ways, as I point out in that other thread I mentioned, of defining "sin(x)" and "cos(x)". One way, for example, is to define them in terms of power series, the other as solutions to initial value, differential equation, problems. In neither of those is x interpreted as being a angle- but in order to use the "sin" and "cos" keys on your calculator you have to use the "radian" mode.
I prefer the last because that makes it easier to prove the periodicity (though it is still a chore!) of sine and cosine.
I also prefer that method as the most rigorous.
It's not that easy to understand for a teenager just learning about generalizations of the trig functions, though.
FAQ: What is sin(1) , not sin(10) and not sin(1c) ?
What is the value of sin(1)?
The value of sin(1) is approximately 0.8415. This is the trigonometric function representing the ratio of the length of the side opposite an angle of 1 radian to the length of the hypotenuse in a right triangle.
Why is sin(10) considered a sin?
The term "sin" in mathematics is used to refer to the sine function, which is a trigonometric function. The value of sin(10) is approximately -0.5440, which is considered a sin because it is a negative value. However, in a religious or moral context, the term "sin" may have a different meaning.
What is the difference between sin(1) and sin(1c)?
Both sin(1) and sin(1c) represent the sine function, but the input values are different. In sin(1), the input value is in radians, while in sin(1c), the input value is in degrees. This results in different output values. Sin(1) is approximately 0.8415, while sin(1c) is approximately 0.0175.
Can sin(1) be negative?
Yes, sin(1) can be negative. In fact, the value of sin(1) is negative for angles between 180 and 360 degrees, or between π and 2π radians. This is because in these quadrants, the side opposite the angle is negative, resulting in a negative ratio.
How is sin(1) related to other trigonometric functions?
Sin(1) is related to other trigonometric functions, such as cosine and tangent, through the unit circle. These functions represent different ratios of the sides of a right triangle in relation to an angle. For example, sin(1) is the ratio of the opposite side to the hypotenuse, while cosine is the ratio of the adjacent side to the hypotenuse.
