What is Stochastic Quantum Mechanics (in simple terms)?
In summary, stochastic mechanics is a mechanical theory that incorporates a level of randomness or probabilistic behavior into the predictions of quantum mechanics. It differs from quantum mechanics in that it does not consistently produce accurate predictions, but rather shows that much of quantum mechanics can be explained through the randomness created when measurements are made and other assumptions made by stochastic mechanics. However, there are still disagreements between the two theories, particularly in regards to nonlocality and the role of Brownian motion in stochastic mechanics.
john taylor
24
Could someone, in laymen's terms explain to me what stochastic mechanics is?
Likes Peter Morgan
Before the position, velocity, or some QM property of a particle is measured, a probabilistic range of potential measurement results can be predicted.
But the exact measurement result cannot be fully predicted. In that sense, there is an element of randomness whenever an attempt is made at such a measurement.
The mechanics can be viewed as not fully deterministic. Thus: stochastic mechanics; mechanical rules that include an unavoidable element of randomness.
I am looking at this article: https://iopscience.iop.org/article/10.1088/1742-6596/361/1/012011/pdf
In the introduction, it described stochastic mechanics (SM) as an "interpretation" or quantum mechanics (QM). But it is not. One interpretation of a theory, such as QM, should yield the same predictions as any other interpretation. But the article goes on to show that the model generated by SM is not equivalent to QM. QM makes consistently accurate predictions. SM does not.
What SM does show is that there are is an awful lot of QM that results from no more than the randomness created when measurements are made - and other assumptions made by SM.
Unfortunately, as I read through the material, I cannot identify exactly what those other assumptions are.
.Scott said:
That's a nice summary. Unlike the wikipedia article, it actually gives an idea of what stochastic mechanics is about.
Nelson seems to claim that the predictions are the same for actual experiments. In the last paragraph of the paper you cited, he writes:
"Why do I not suggest that the experiment be done? Because if a record of the observation of the first oscillator at time t1 is made by some physical means, and similarly for the second oscillator, and the two records arecompared at a common later time t3, this is an observation at a single time, for which quantum mechanics and stochastic mechanics agree. The nonlocality of stochastic mechanics conspires to bring the records into agreement."
This doesn't seem right to me. The main feature of stochastic mechanics is to have a Brownian motion like stochastic movement of particles going on all the time which gives the Schrödinger equation the status of some kind of diffusion equation. Up to this point in the description, no measurements are involved.
Likes dextercioby and .Scott
Related to What is Stochastic Quantum Mechanics (in simple terms)?
1. What is stochastic quantum mechanics?
Stochastic quantum mechanics is a theoretical framework that combines quantum mechanics, the study of the behavior of matter and energy at a microscopic level, with stochastic processes, which are random processes that describe the evolution of a system over time.
2. How does stochastic quantum mechanics differ from traditional quantum mechanics?
Traditional quantum mechanics uses deterministic equations to describe the evolution of a system, while stochastic quantum mechanics incorporates randomness into the equations. This allows for a more realistic description of certain physical phenomena, such as the behavior of particles in a complex environment.
3. What are some applications of stochastic quantum mechanics?
Stochastic quantum mechanics has been used to study a variety of systems, including chemical reactions, biological processes, and quantum computing. It has also been applied to fields such as finance and economics, where random fluctuations play a significant role.
4. How does stochastic quantum mechanics relate to the uncertainty principle?
The uncertainty principle, a fundamental principle in quantum mechanics, states that it is impossible to know both the position and momentum of a particle with absolute certainty. Stochastic quantum mechanics takes this principle into account by incorporating randomness into the equations, allowing for a more accurate description of a system's behavior.
5. Is stochastic quantum mechanics widely accepted in the scientific community?
Stochastic quantum mechanics is a relatively new theoretical framework and is still being actively researched and debated in the scientific community. While some scientists have embraced it as a more realistic approach to understanding complex systems, others remain skeptical and continue to use traditional quantum mechanics. Further research and experimentation are needed to fully understand the implications and applications of stochastic quantum mechanics.
  • Quantum Interpretations and Foundations
  • Quantum Physics
  • Quantum Physics
