What is susceptibility in physics?
In summary, susceptibility is a property of material that measures its ease of polarization (electric susceptibility) or strengthening of a magnetic field (magnetic susceptibility). It can be represented by operators (generally tensors) that convert one vector field to another. It is dimensionless and has no units. Susceptibility also plays a role in converting electric and magnetic fields to polarization and magnetization fields, respectively. It is important to note that susceptibility is different in isotropic and non-isotropic materials, with the latter being represented by tensors. Second-order susceptibility is used in non-linear optics.
10,322
Definition/Summary
Susceptibility is a property of material. In a vacuum it is zero.
Susceptibility is an operator (generally a tensor), converting one vector field to another. It is dimensionless.
Electric susceptibility [itex]\chi_e[/itex] is a measure of the ease of polarisation of a material.
Magnetic susceptibility [itex]\chi_m[/itex] is a measure of the strengthening of a magnetic field in the presence of a material.
Diamagnetic material has negative magnetic susceptibility, and so weakens a magnetic field.
Equations
Electric susceptibility [itex]\chi_e[/itex] and magnetic susceptibility [itex]\chi_m[/itex] are the operators which convert the electric field and the magnetic intensity field, [itex]\varepsilon_0\mathbf{E}[/itex] and [itex]\mathbf{H}[/itex] ([itex]not[/itex] the magnetic field [itex]\mathbf{B}[/itex]), respectively, to the polarisation and magnetisation fields [itex]\mathbf{P}[/itex] and [itex]\mathbf{M}[/itex]:
[tex]\mathbf{P}\ = \chi_e\,\varepsilon_0\,\mathbf{E}[/tex]
[tex]\mathbf{M}\ = \chi_m\,\mathbf{H}\ = \frac{1}{\mu_0}\,\chi_m\,(\chi_m\,+\,1)^{-1}\,\mathbf{B}\ = \frac{1}{\mu_0}\,(1\,-\,(\chi_m\,+\,1)^{-1})\,\mathbf{B}[/tex]
Extended explanation
Bound charge and current:
Electric susceptibility converts [itex]\mathbf{E}[/itex], which acts on the total charge, to [itex]\mathbf{P}[/itex], which acts only on bound charge (charge which can move only locally within a material).
Magnetic susceptibility converts [itex]\mathbf{H}[/itex], which acts on free current, to [itex]\mathbf{M}[/itex], which acts only on bound current (current in local loops within a material, such as of an electron "orbiting" a nucleus).
Relative permittivity [itex]\mathbf{\varepsilon_r}[/itex] and relative permeability [itex]\mathbf{\mu_r}[/itex]:
[tex]\mathbf{\varepsilon_r}\ =\ \mathbf{\chi_e}\ +\ 1[/tex]
[tex]\mathbf{\mu_r}\ =\ \mathbf{\chi_m}\ -\ 1[/tex]
[tex]\mathbf{D}\ =\ \varepsilon_0\,\mathbf{E}\ +\ \mathbf{P}\ =\ \varepsilon_0\,(1\,+\,\mathbf{\chi_e})\,\mathbf{E}\ =\ \mathbf{\varepsilon_r}\,\mathbf{E}[/tex]
[tex]\mathbf{B}\ =\ \mu_0\,(\mathbf{H}\ +\ \mathbf{M})\ =\ \mu_0\,(1\,+\,\mathbf{\chi_m})\,\mathbf{H}\ =\ \mathbf{\mu_r}\,\mathbf{H}[/tex]
Note that the magnetic equations analogous to [itex]\mathbf{P}\ = \mathbf{\chi_e}\,\varepsilon_0\,\mathbf{E}[/itex] and [itex]\mathbf{D}\ =\ \mathbf{\varepsilon_r}\,\mathbf{E}[/itex] are [itex]\mathbf{M}\ = \frac{1}{\mu_0}\,(1\,-\,(\mathbf{\chi_m}\,+\,1)^{-1})\,\mathbf{B}[/itex] and [itex]\mathbf{H}\ =\ \mathbf{\mu_r}^{-1}\,\mathbf{B}[/itex]
In other words, the magnetic analogy of relative permittivity is the inverse of relative permeability, and the magnetic analogy of electric susceptibility is the inverse of a part of magnetic susceptibility.
Permittivity: [itex]\mathbf{\varepsilon}\ =\ \varepsilon_0\,\mathbf{\varepsilon_r}[/itex]
Permeability: [itex]\mathbf{\mu}\ =\ \mu_0\,\mathbf{\mu_r}[/itex]
Units:
Relative permittivity and relative permeability, like susceptibility, are dimensionless (they have no units).
Permittivity is measured in units of farad per metre ([itex]F.m^{-1}[/itex]).
Permeability is measured in units of henry per metre ([itex]H.m^{-1}[/itex]) or tesla.metre per amp or Newton per amp squared.
cgs (emu) values:
Some books which give values of susceptibility use cgs (emu) units for electromagnetism.
Although susceptibility has no units, there is still a dimensionless difference between cgs and SI values, a constant, [itex]4\pi[/itex]. To convert cgs values to SI, divide by [itex]4\pi[/itex] for electric susceptibility, and multiply by [itex]4\pi[/itex] for magnetic susceptibility.
Tensor nature of susceptibility:
For crystals and other non-isotropic material, susceptibility depends on the direction, and changes the direction, and therefore is represented by a tensor.
For isotropic material, susceptibility is the same in every direction, and [itex]\mathbf{P}[/itex] (or [itex]\mathbf{M}[/itex]) is in the same direction as [itex]\mathbf{E}[/itex] (or [itex]\mathbf{H}[/itex]):
[tex]\mathbf{P}\ = \varepsilon_0\,\chi_e\,\mathbf{E}[/tex]
where [itex]\chi_e[/itex] is a multiple of the unit tensor, and therefore is effectively a scalar:
[tex]P^i\ =\ \varepsilon_0\,\chi_e\,E^i[/tex]​
Ordinary susceptibility is a tensor (a linear operator whose components form a 3x3 matrix) which converts one vector field to another:
[tex]P^i\ =\ \varepsilon_0\,\chi_{e\ j}^{\ i}\,E^j[/tex]
Second-order susceptibility is a tensor (a linear operator whose components form a 3x3x3 "three-dimensional matrix") which converts two copies of one vector field to another:
[tex]P^i\ =\ \varepsilon_0\,\chi_{e\ \ jk}^{(2)\,i}\,E^j\,E^k[/tex]
It is used in non-linear optics.
Susceptibility, being a tensor, is always linear in each of its components. The adjective "non-linear" refers to the presence of two (or more) copies of [itex]\bold{E}[/itex].
More generally, one can have:
[tex]P^i\ =\ \varepsilon_0\,\sum_{n\ =\ 1}^{\infty}\chi_{e\ \ \ j_1\cdots j_n}^{(n)\,i}\,E^{j_1}\cdots E^{j_n}[/tex]
* This entry is from our old Library feature. If you know who wrote it, please let us know so we can attribute a writer. Thanks!
Likes Jared Edington
FAQ: What is susceptibility in physics?
1. What is susceptibility in physics?
Susceptibility in physics is a measure of how easily a material can be magnetized when exposed to an external magnetic field. It is a fundamental property of materials and is used to describe the response of a material to magnetic fields.
2. How is susceptibility measured?
Susceptibility is typically measured by applying an external magnetic field to a sample of the material and measuring the resulting magnetization. This can be done using various techniques such as SQUID magnetometry or vibrating sample magnetometry.
3. What factors affect susceptibility?
The susceptibility of a material can be affected by various factors including temperature, composition, and molecular structure. In general, materials with strong magnetic moments and low thermal energy tend to have higher susceptibility.
4. What is the difference between magnetic susceptibility and electric susceptibility?
Magnetic susceptibility measures the response of a material to magnetic fields, while electric susceptibility measures the response to electric fields. Both are related to the ability of a material to be polarized, but the mechanisms behind each type of susceptibility are different.
5. How is susceptibility used in practical applications?
Susceptibility is used in a wide range of practical applications, such as in the development of magnetic materials for electronic devices, in medical imaging techniques like MRI, and in geophysical surveys to detect subsurface mineral deposits. It is also important in understanding the behavior of materials in Earth's magnetic field and in studying the properties of stars and galaxies.
