What is the acceleration of the cart? :)
In summary, the man pulls himself up the incline by using a pulley system and extracts 250 N of force on the rope. This results in a 5.566 m/2^2 acceleration.
Dusty912
149
A man is pulling himself up the 15 degree incline by the method shown. If the combined mass of the man and the cart is 100kg, determine the acceleration of the cart if the man excerpts 250 N on the rope. There is also a .2 coefficient for the kinetic friction between the wheels and the ground.
F=m*a
Fk=μ*N
So I pretty much know how to solve this without friction being involved. Where T is the friction in the rope, m is the mass of the man and cart theta is the angle, and a is acceleration.
F=m*a
4T-m*g*sinθ=m*a
now when you throw friction into the mix should it look like this?
F=m*a
4T-m*g*sinθ-μ*N=m*a
4T-m*g*sinθ-μ*m*g*cosθ=m*a
with the numerical values
4*(250)-100*9.81*sin(15)-.2*100*9.81*cos(15)=100*a
a=5.566m/2^2Thanks ahead of time, you all rock
Dusty912 said:
by the method shown
Is there a figure you can attach?
Sack the question setter. Presumably the wheels are rolling, so kinetic friction between them and the ground is irrelevant, and static friction would not cost any energy. It should say "rolling resistance", not friction. (0.2 is rather high.)
You mean tension, I assume.
Dusty912 said:
4T
I infer that the pulley system involves four lengths of rope between the cart and the top of the slope. If so, your method and answer look fine.
yea, tension in the rope not friction
and are you saying the question is worded incorrectly? because that was a word for word question by professor wrote
okay well thanks for pointing that out. we have a forum for our class, so I'll let others know.
Related to What is the acceleration of the cart? :)
1. What is acceleration?
Acceleration is the rate of change of an object's velocity over time. It is a vector quantity, which means it has both magnitude (speed) and direction.
2. How is acceleration calculated?
Acceleration can be calculated using the formula a = (vf-vi)/t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time. Alternatively, it can also be calculated as the derivative of velocity with respect to time.
3. What is the unit for acceleration?
The unit for acceleration is meters per second squared (m/s²) in the metric system, and feet per second squared (ft/s²) in the imperial system.
4. How does acceleration affect the motion of an object?
Acceleration affects the motion of an object by changing its velocity. If the acceleration is in the same direction as the velocity, the object will speed up. If the acceleration is in the opposite direction, the object will slow down. If the acceleration is perpendicular to the velocity, it will change the direction of motion.
5. How is acceleration related to force?
According to Newton's Second Law of Motion, the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. This means that a greater force will result in a larger acceleration, and a smaller mass will also result in a larger acceleration.
