- #36
bhobba
Mentor
- 10,823
- 3,689
hellsteiger said:Seems to me there is some sort of relativity here, that to someone outside of a system, it is seen as being in a pure state, regardless of whether decoherence is occurring within that system for whatever reasons.If this outside observer where to then interact with the system it could be put into a mixed state. Or should I interpret it more this way: a state is pure unless collisions occur within the system that cause it to decohere regardless of whether the system is closed or not.
Its none of those things.
Here is a paper that explains it:
http://philsci-archive.pitt.edu/5439/1/Decoherence_Essay_arXiv_version.pdf
If you don't know the technical details of QM then the above paper is likely gibberish - but unfortunately the jig is up with this one in explaining it in lay terms.
I will do my best - but it is almost certainly very unsatisfactory.
After decoherence a superposition is converted to a mixed state. Observationally its exactly the same as if collapse occurred - there is no way to tell the difference. It explains what's called apparent collapse. Now there are two types of mixed states - the ones from decoherence - and those called proper. The difference is if it was proper then collapse would have actually occurred rather than simply apparently occurred. There is an interpretation called the ignorance interpretation that I hold to that is very simple - all you do is say - somehow - the mixed state is a proper mixed state. How does that happen - blank out - that's why its called the ignorance interpretation.
Thanks
Bill
