What is the AM-GM Inequality Used For?
In summary, the concept of determining the minimum value is to find the smallest value or number in a given set of data or range of values. It is important because it provides insights into the data and helps in making informed decisions, and it can also be used to identify outliers or anomalies. There are various methods used to determine the minimum value, including graphical, numerical, and statistical methods. The minimum value can be interpreted as the lowest or smallest value in a set of data and can represent the starting point for further analysis. However, there are limitations to determining the minimum value, such as only considering the smallest value and not providing information about other data points, and it may not be useful in the presence of outliers or skewed data.
anemone
MHB
POTW Director
3,883
115
Determine the minimum value of \(\displaystyle \frac{\sec^4 a}{\tan^2 b}+\frac{\sec^4 b}{\tan^2 a}\) over all $a,b \ne \frac{k \pi}{2}$ where $k$ is in $Z$.
Mathematics news on Phys.org
Since $a$ and $b$ are symmetric in the expression, I will set $a=b$, and then define
$$f(a)= \frac{2 \sec^{4}(a)}{ \tan^{2}(a)}= \frac{2}{ \cos^{2}(a) \sin^{2}(a)}.$$
Differentiating yields
\begin{align*}
f'(a)&= \frac{-2(-2 \cos(a) \sin^{3}(a)+2 \sin(a) \cos^{3}(a))}{ \cos^{4}(a) \sin^{4}(a)} \\
&= \frac{-4 \sin(a) \cos(a) [ \cos^{2}(a)- \sin^{2}(a)]}{ \sin^{4}(a) \cos^{4}(a)} \\
&= \frac{-4 \cos(2a)}{ \sin^{3}(a) \cos^{3}(a)}.
\end{align*}
Setting $f'(a)=0$ implies that
$$2a= \frac{(2j+1) \pi}{2} \implies a=\frac{(2j+1) \pi}{4}.$$
Just to make sure, let us look for values of $a\in (0, \pi) \setminus \{\pi/2 \}$. This turns out to require $j=0,1$, and therefore $a\in \{ \pi/4, 3 \pi/4 \}$. Plugging either of these into $f$ yields the minimum value of $8$.
To be complete, we should take the second derivative $f''(a)$, and show that it is positive at these values. I will leave that to the reader.
Here's my solution
Using the usual identity we have
$\dfrac{(\tan^2 a + 1)^2}{\tan^2b}+\dfrac{(\tan^2 b + 1)^2}{\tan^2a}.$
If we let $x = \tan a$ and $y = \tan b$ then we have
$z = \dfrac{(x^2 + 1)^2}{y^2}+\dfrac{(y^2 + 1)^2}{x}.$
Using the standard first derivatives we have (noting that $x,y \ne 0$)
$\dfrac{\partial z}{\partial x} = 4\,{\dfrac { \left( {x}^{2}+1 \right) x}{{y}^{2}}}-2\,{\dfrac { \left( {
y}^{2}+1 \right) ^{2}}{{x}^{3}}}$
$\dfrac{\partial z}{\partial y} = 4\,{\dfrac { \left( {y}^{2}+1 \right) y}{{x}^{2}}}-2\,{\dfrac { \left( {
x}^{2}+1 \right) ^{2}}{{y}^{3}}}$
Simplify and setting these to zero gives
\begin{align}
2\,{x}^{6}+2\,{x}^{4}-{y}^{6}-2\,{y}^{4}-{y}^{2} &= 0\;\;\;(*)\\
-{x}^{6}-2\,{x}^{4}-{x}^{2}+2\,{y}^{6}+2\,{y}^{4}&=0
\end{align}$
Multiplying the first by $x^2+1$ and the second by $2x^2$ and adding gives
${y}^{2} \left( {y}^{2}+1 \right) \left( 3\,{y}^{2}{x}^{2}-{y}^{2}-1-{
x}^{2} \right) =0$
from which we can solve for $y^2$ giving $y^2 = \dfrac{x^2+1}{3x^2-1}$ noting that $3x^2-1 \ne 0$. Substituting into (*) and factoring gives $x = \pm 1$ which in turn gives $y = \pm 1$ giving the minimum value of $z$ as $8$. The second derivative test verifies this.
\begin{align*}
\end{align*}
Just a note
If we write your function as
$f(a) = 8 \csc^2 2a$
It becomes obvious that the minimum is 8
Hi Ackbach and Jester,
Thank you for participating...and yes, the answer is correct.
The solution that comes along with this particular problem suggests the use of the AM-GM inequality to solve it...let's see...
If we let $x = \tan^2 a$ and $y = \tan^2 b$ then we have
\(\displaystyle \frac{(\tan^2 a + 1)^2}{\tan^2b}+\frac{(\tan^2 b + 1)^2}{\tan^2a} = \frac{(x + 1)^2}{y}+\frac{(y + 1)^2}{x}\)
\(\displaystyle \;\;\; \;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;= \frac{x^2 + 2x+1}{y}+\frac{y^2 +2y+ 1}{x}\)
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;= \left(\frac{x^2}{y}+\frac{1}{y}+\frac{x^2}{y}+ \frac{1}{x}\right)+2(\frac{x}{y}+\frac{y}{x})\)
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\ge 4\sqrt[4]{\frac{x^2}{y}\cdot\frac{1}{y}\cdot\frac{x^2}{y} \cdot\frac{1}{x}}+2\left(2\sqrt{\frac{x}{y}\cdot \frac{y}{x}}\right)\)
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\ge 4+4\)
\(\displaystyle \;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\;\ge 8\)
Equality holds when $x=y=1$, i.e. $a=\pm 45^{\circ}+k\cdot180^{\circ}$, $b=\pm 45^{\circ}+k\cdot180^{\circ}$ for integer $k$.
FAQ: What is the AM-GM Inequality Used For?
What is the concept of determining the minimum value?
The concept of determining the minimum value is to find the smallest value or number in a given set of data or range of values. It is used in various fields such as statistics, optimization, and decision-making processes.
Why is it important to determine the minimum value?
Determining the minimum value is important because it provides insights into the data and helps in making informed decisions. It can also be used to identify outliers or anomalies in the data.
What are the methods used to determine the minimum value?
There are various methods used to determine the minimum value, including graphical methods, numerical methods, and statistical methods. These methods involve calculations and comparison of values to find the smallest one.
How do you interpret the minimum value?
The minimum value can be interpreted as the lowest or smallest value in a set of data. It can also represent the starting point or baseline for further analysis and comparison.
What are the limitations of determining the minimum value?
One of the limitations of determining the minimum value is that it only considers the smallest value and does not provide information about the other data points. Also, it may not always be a useful measure in the presence of outliers or skewed data.
