What is the amount of energy released from an exploding firecracker?
In summary, the conversation discusses different experimental approaches involving a firecracker and a pendulum. One suggestion is to make a pendulum with a cup on the end and use the explosion of the firecracker to rotate it, while another suggestion is to use a calorimeter. The use of standard enthalpy tables is also mentioned as a possible method.
Sack Boy
Let's say the standard size firecracker if there is a standard.
What about doing an experiment? Make a pendulum with a little cup on the end and set the firecracker in their and try to focus the explosion so it will rotate the pendulum ,
Then measure the change in height of the pendulum . mgh is the gravitational potential energy. Ballistic pendulum idea or do something with momentum conservation.
Nope. Too many losses, would introduce errors on the order of 50% or more.
Using standard enthalpy tables will get you quite close to the answer.
Perhaps the best experimental approach is to make the firecracker explode in a calorimeter. Some ideas are probably mentioned in this book: http://www.springerlink.com/content/x40850v6628r6270/
The amount of energy released from an exploding firecracker can vary depending on the size and composition of the firecracker. However, on average, a standard size firecracker can release anywhere from 1 to 5 joules of energy. This energy is released in the form of heat, light, and sound as the chemical reactions within the firecracker rapidly release stored energy. It is important to note that the amount of energy released can be affected by factors such as temperature, humidity, and altitude.
FAQ: What is the amount of energy released from an exploding firecracker?
1. What is the definition of an exploding firecracker?
An exploding firecracker is a small, explosive device that is typically made of paper or cardboard and filled with gunpowder or flash powder. When ignited, the gunpowder undergoes a rapid chemical reaction, creating a loud explosive sound and releasing a burst of energy.
2. How much energy is released from an exploding firecracker?
The amount of energy released from an exploding firecracker varies depending on the size and composition of the firecracker. On average, a firecracker can release anywhere from 100 to 200 joules of energy.
3. How is the energy from an exploding firecracker measured?
The energy released from an exploding firecracker is typically measured in joules or calories. This can be calculated by using the formula E=mc², where E is energy, m is mass, and c is the speed of light.
4. Can the energy from an exploding firecracker be harmful?
Yes, the energy released from an exploding firecracker can be harmful if proper safety precautions are not taken. The explosion can cause burns, cuts, and even hearing damage if the firecracker is too close to the body when it detonates.
5. How does the energy from an exploding firecracker compare to other explosive devices?
The energy released from an exploding firecracker is relatively low compared to other explosive devices such as bombs or missiles. For example, a hand grenade can release over 1,000 joules of energy, while a firecracker typically releases only 100-200 joules.
12K
