What is the angle and rate of change when flying a kite?
In summary: You can also convert it to degrees per second by multiplying by $\frac{180}{\pi}$.Regards,|\pi\rangleIn summary, the dragon is 15m away and moves straight up while the rope is rolled out at a speed of 4 dm/s and 30m is unwound. The angle between the line and ground at this moment is 60 degrees, and the rate of change of the angle is 0.44106 degrees per second.
Petrus
702
You fly a kite. The dragon is 15m away from you (measured horizontally) and
moves right now straight up. The rope is rolled out with the speed of 4 dm / s, and 30m
is unwound. (a) Draw a clear picture of the situation, and explain what all introduced
designations stand for.
(b) What is the angle between the line and ground at this moment?
(c) How fast the angle changes? Also calculate the value to degrees per second
and consider whether it is reasonable.my progress:
(a)
(b)\(\displaystyle \cos^{-2}( \frac{15}{30})=60degree\)
(c) i need help with this part I know that dz/dt=0.4m/s
Regards,
\(\displaystyle |\pi\rangle\)
Hey Petrus! :)
Perhaps you can draw a second picture that shows the situation some time $t$ later?
And then calculate the angle in this situation?
Btw, your assumption that $dz/dt=0.4 \text{ m/s}$ is incorrect.
The problem statement says that the line gets unwound at $0.4 \text{ m/s}$.
That is not the same as the height increasing at this rate.
I like Serena said:
Hey Petrus! :)
do you mean like 2 second later the hypotenuse is 30.8m and the bottom 15.8m did i get it correct?
Regards,
The hypotenuse would indeed become 30.8 m.
But according to your problem statement the kite rises straight up meaning the bottom would still be 15 m.
Btw, I would try to generalize it for an arbitrary time $t$.
If you have the angle as function of $t$ you can then differentiate it.
do you mean like this \(\displaystyle cos(x)=\frac{30+0.4t}{15}\) so i got \(\displaystyle x=\cos^{-1}(\frac{30+0.4t}{15})\)
Regards,
Regards,
Almost! ;)
It should be:
$$x=\cos^{-1}\left(\frac{15}{30+0.4t}\right)$$
Now you can take the derivative to find the rate of change of the angle.
I like Serena said:
Huh? :confused:
Which "after"?
Anyway, you can substitute $t=0$ to find the current rate of change of the angle.
See Wolfram|Alpha here.
yes i get that, but i have hard understanding what is the unit. I mean this is not degree is it m/s? or i am lost..
edit: if i get it correct then after 0 secund its that much in meter?
Regards,
We're talking about the rate of change of the angle.
By default W|A will use the unit $\text{rad/s}$.
ok so we got 0.44106 degree/sec right?
Regards,
Yep! :D
FAQ: What is the angle and rate of change when flying a kite?
How do you calculate the height of a kite when flying?
To calculate the height of a kite, you will need to measure the length of the kite string and the angle of elevation from the ground to the top of the kite. Then, you can use the trigonometric function tangent to find the height of the kite. The formula is height = length of kite string * tangent(angle of elevation).
What is the best place to fly a kite?
The best place to fly a kite is an open area with consistent wind flow, such as a park or beach. Avoid flying kites near power lines, buildings, or trees to prevent accidents.
How does the wind affect the flight of a kite?
The wind is essential for flying a kite as it provides the necessary lift and allows the kite to stay airborne. Stronger winds can lift the kite higher, while lighter winds may require more effort to keep the kite in the air.
Can you control the direction of a kite while flying?
Yes, you can control the direction of a kite while flying by adjusting the angle of the kite's tail or by pulling on the kite string. You can also use your body movements to guide the kite in a specific direction.
What should I do if my kite gets stuck in a tree or power line?
If your kite gets stuck in a tree or power line, do not attempt to climb or retrieve it yourself. Instead, seek help from a trained professional to safely remove the kite. It is also a good idea to fly kites away from areas with potential hazards to avoid this situation.
