What is the angle of static equilibrium for a ladder on ice?
The discussion focuses on determining the tension in a rope supporting a foldable step ladder weighing 150 N, positioned at a 60° angle on ice. Participants emphasize the importance of showing work, such as free body diagrams (FBD), to receive assistance in solving the problem. There are challenges in equating torques around the ladder's pivots, with users noting a lack of progress in calculations. Clarification is sought regarding the ladder's configuration and the angle's application to each half. Effective problem-solving requires a clear demonstration of the steps taken and where difficulties arise.
engineerr
A foldable step ladder weighing 150 𝑁 is made of two halves connected by a pivot on top and
by a rope in the middle. The ladder is put on ice and its angle with the surface is 60°. What is
the tension of the rope?
net torque = zero
tried equating torques around the pivots of the ladder and equating them to zero but I'm not getting anywhere with that.
engineerr said:
Homework Statement: A foldable step ladder weighing 150 𝑁 is made of two halves connected by a pivot on top and
Relevant Equations: net torque = zero
Start with some diagrams (FBD). You aren't receive help until you show an honest effort has been made.
We can't help you unless you show us what you did. Just mentioning it is not enough. We have to know where you got stuck or what you did wrong.
Welcome, @engineerr !
Could you clarify this part?
“The ladder is put on ice and its angle with the surface is 60°.”
Each half, I assume.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
