anemone
MHB
POTW Director
- 3,883
- 115
In triangle $PQR$, let $D$ be the midpoint of $QR$. If $\angle PDQ=45^{\circ}$ and $\angle PRD=30^{\circ}$, determine $\angle QPD$.
anemone said:In triangle $PQR$, let $D$ be the midpoint of $QR$. If $\angle PDQ=45^{\circ}$ and $\angle PRD=30^{\circ}$, determine $\angle QPD$.
Plato said:From the given you know [tex]m\left( {\angle PDR} \right)\;\& \;m\left( {\angle DPR} \right)~.[/tex]
You also know [tex]m\left( {\angle PQD} \right)+m\left( {\angle QPD} \right)=135^o[/tex].
Can you finish?
mente oscura said:Hello.
1º)[tex]\angle DPR=180º-(180º-45º)-30º=15º[/tex]
2º) Draw the height from [tex]Q \ to \ \overline{PR}[/tex], getting the point [tex]O[/tex]
[tex]\sin 30º=\dfrac{1}{2} \ then \ \overline{QO}=\overline{QD}=\overline{DR}[/tex]
3º) [tex]\angle PDO=60º-45º=15º[/tex]
4º) For 1º) [tex]\overline{OP}=\overline{OD}=\overline{QO} \rightarrow{} \angle PQO=\angle QPO=45º[/tex]
5º) For 4º): [tex]\angle QPD=45º-15º=30º[/tex]
Regards.
The angle PQR is the angle formed by three points, P, Q, and R, with vertex at point Q.
To determine the angle PQR, you can use the formula: angle PQR = 180 - (angle P + angle R).
The unit of measurement for the angle PQR depends on the unit of measurement used for angles in the given context. It can be in degrees, radians, or other units.
The range of values for the angle PQR is between 0 and 180 degrees, or 0 and π radians. This is because an angle cannot be greater than 180 degrees or π radians in a triangle.
No, the angle PQR cannot be negative. It is always measured in a counterclockwise direction from the initial side to the terminal side, and thus, it can only have positive values.
