What is the apparent magnitude of the binary system?
In summary: Earth" and use the Pythagorean theorem to solve for L_2.2. You are trying to do something that is not possible. You can't just add up the luminosities of each star and then use the M-L relation to determine the apparent magnitude of the system. This is because the M-L relation is non-linear. You need to compute the absolute magnitude of the binary system first and then use the distance modulus formula to convert that into an apparent magnitude.
PaulWright
Two stars are in a circular visual binary system. The orbital
period of the binary is 30 years. The distance to the binary is 20
parsecs. The angular radius of the orbit of each star is 1". What
are the masses of the two stars?
each star works out to be 4.4 solar mass
2. From your result above, what should be the apparent magnitude of
the binary as a whole? You may assume that both stars are on the main
sequence, and that the standard mass-luminosity relationship applies
here. You may further assume that the absolute magnitude of the Sun
is 5.7. (Note: full credit for this question will be given for
answers that follow the right prodcedure, but start with an incorrect
answer to question 1).
m=M+5(log(d)-1)
mass of the whole binary system is 8.8M(sun)
I have no idea what the mass luminosity relationship is.
I just need some help getting started.
Cheers,
Paul
You'll learn about it if you take a course in stellar astrophysics. For now, this article has everything you need to know:
http://en.wikipedia.org/wiki/Mass-luminosity_relation
This relation will tell you the luminosity of each star in units of solar luminosities. Then, since you have the ratio of the combined luminosity of both stars to the luminosity of the sun, you can figure out the difference in absolute magnitude between two of these stars and the sun. Since you are given the abs. magnitude of the sun, this in turn tells you the absolute magnitude of the two binaries. You can then use that to determine the apparent magnitude of the system using the formula you posted.
L/L_sun = 2022
-25.9=-2.5log\frac{F_{sun}}{F_0}\\
m=-2.5log\frac{F}{F_0}\\
equating
\frac{10^{10.36}=F_{sun}}{10^{\frac{m}{-2.5}}=F}\\
\frac{10^{10.36}}{10^{\frac{m}{-2.5}}} = 2022
therefore
m=-17.64
Can you please advise me on what I have done wrong here?
(I was having problems inserting the latex in the tex tags, sorry)
Cheers.
1. Your luminosity is wrong. You should compute the luminosity of each star separately using the M-L relation and THEN add those L's together. This is not the same as adding up the masses and then applying the M-L relation (which is wrong). A single 8.8 solar mass star is significantly more luminous than two 4.4 solar mass stars. This should be obvious, because the M-L relation is NON-linear (just look at it).
I'll get back to you on some of the later steps in a bit.
ah that does make a lot more sense. So the ratio of the L/Lsun = 357.4
2. Okay, for the later steps of the problem, I think that what you're doing wrong is that you first have to compute the absolute magnitude of the binary system, and then use the distance modulus formula to convert that into an apparent magnitude.
To compute the absolute magnitude, it suffices to use the luminosities. You shouldn't have to deal with anything related to fluxes. After all, absolute magnitude IS luminosity in the sense that it is just another way of representing the same quantity -- namely the intrinsic energy output rate of a body (in the form of light). So let's say you have computed the luminosity (L) of a single component of the binary in units of solar luminosities. In other words, you have computed:
[tex] \frac{L}{L_\odot} [/tex]​
You can get the difference in the absolute magnitudes of the binary system and the sun as follows:
[tex] M_{\textrm{bin}}-M_{\textrm{sun}}= -2.5\log\left(\frac{L_{\textrm{bin}}}{L_\odot}}\right) = -2.5\log\left(\frac{2L}{L_\odot}\right) [/tex]​
Here, [itex]M_{\textrm{sun}}[/itex] is the absolute magnitude of the sun (as opposed to [itex] M_\odot[/itex], which is the mass of the sun). So, differences in absolute magnitude measure ratios of luminosities. In general for two objects:
[tex] M_1-M_2= -2.5\log\left( \frac{L_1}{L_2}\right) [/tex]​
If you don't believe me, you should work out this result yourself. Hint: start with the definition of absolute magnitude as "the apparent magnitude that an object would have if it were at a distance of 10 pc."
Cheers.
Can I confirm that the absolute magnitude is 0.6830?
I mean -0.6830
PaulWright said:
I mean -0.6830
That's also what I get, assuming the 4.4 solar masses is right.
Cheers.
Related to What is the apparent magnitude of the binary system?
The apparent magnitude of a binary system is a measure of its brightness as seen from Earth. It is determined by adding the individual apparent magnitudes of each component of the binary system.
How is the apparent magnitude of a binary system calculated?
The apparent magnitude of a binary system is calculated by adding the individual apparent magnitudes of each component of the system. The apparent magnitude is a logarithmic scale, with lower numbers indicating brighter objects and higher numbers indicating dimmer objects.
What factors affect the apparent magnitude of a binary system?
The apparent magnitude of a binary system can be affected by several factors, including the brightness and distance of the individual components, any intervening dust or gas, and the angle at which the system is viewed from Earth.
What is the difference between apparent magnitude and absolute magnitude in a binary system?
Apparent magnitude is a measure of the brightness of a binary system as seen from Earth, while absolute magnitude is a measure of the intrinsic brightness of the system. Absolute magnitude takes into account the distance from Earth, while apparent magnitude does not.
How is the apparent magnitude of a binary system used in astronomy?
The apparent magnitude of a binary system is used in astronomy to classify and compare the brightness of different celestial objects. It is also used to determine the distance to objects, as well as to study the evolution and properties of binary systems.
