What is the approximate diameter of the latex balloon after inflation?
In summary, a group of physics students used 1500 liters of helium to inflate a latex sounding balloon for a high altitude experiment. The approximate diameter of the assumed spherical balloon after inflation was calculated to be 1.42 meters, which is different from the supposed correct answer of 3.1 meters. This may suggest that the question was not fully accurate or there were other factors involved.
Dannbr
In a recent high altitude experiment, some physics students used 1500 liter of helium to inflate a latex sounding balloon that would ascend to an altitude of over 30 km. what was the approximate diameter of the (assumed spherical) balloon after inflation?
volume of a sphere= (4/3)(pi)(r^3)
1 liter = 1.0E-3
V=(4/3)(pi)(r^3)
so,
r = [(3V)/(4(pi))]^(1/3)
(1500liter)(1.0E-3m^3/1liter)= 1.5m^3
[((3)(1.5m^3))/((4)(pi))]^(1/3) = .710m
2r = 1.42m
Correct answer should be 3.1 m
Could someone help me out..
Thanks
The supposed correct answer seems out of line for the question posed. Are you sure the problem didn't involve the size of the balloon at 30km altitude? Or that the helium was in some initially compressed condition?
No, copied question word for word. Thanks for taking a look at it.
FAQ: What is the approximate diameter of the latex balloon after inflation?
What is volume and why is it important?
Volume is a measurement of the amount of space occupied by an object or substance. It is important because it allows us to determine the capacity of containers, the amount of a substance needed for a specific task, and to compare the sizes of different objects.
How is volume calculated?
Volume is typically calculated by multiplying the length, width, and height of an object or substance. For a cylinder, the formula for volume is πr²h, where r is the radius and h is the height. For a sphere, the formula is (4/3)πr³, where r is the radius.
What is the relationship between volume and diameter?
The diameter of a circle is the distance across its widest point, passing through the center. In order to find the volume of a cylinder or sphere, the diameter is needed to calculate the radius, which is a crucial component in the volume formulas. Essentially, the diameter helps determine the size of the object or substance, which is necessary in calculating its volume.
How do you find the diameter using volume?
To find the diameter using volume, you will need to know the radius and height of the object or substance. Plug these values into the appropriate formula, and then solve for the diameter. For a cylinder, the formula would be diameter = √(4 x volume / πh). For a sphere, the formula would be diameter = √(6 x volume / π).
Can volume be measured in different units?
Yes, volume can be measured in different units depending on the size and type of object or substance. Common units of volume include liters, cubic centimeters, gallons, and cubic feet. It is important to pay attention to the units when working with volume calculations to ensure accuracy.
