What is the Area of the Shaded Region in Trigonometry Problem?
  • MHB
  • Thread starter Alaba27
In summary: If \sin(x)=\frac{\sqrt{3}}{2} and 0<x<\frac{\pi}{2} then what is $x$?If $\sin(x)=\frac{\sqrt{3}}{2}$ and $0<x<\frac{\pi}{2}$, then $x$ is $\frac{\pi}{2}$.
Alaba27
Hi again,
I'm completing my tutoring booklet for trigonometry and I have a question that is quite difficult. I've never done anything like it and my solutions page only has the final answer. I'd like to see how the result is found step-by-step, so if anyone can help me out or at least guide me to the solution it would be much appreciated.
http://speedcap.net/sharing/files/57/af/57afa49f650622a931c668f649477a83.png
http://speedcap.net/sharing/files/6a/e5/6ae5a228d615fb949ba020cd1a1c725d.png
If you cannot read the question, it is:
sin(x) = (√3)/2 in the circle with centre O, shown on the right. Furthermore AB // OP and m OA = 1 unit. What is the area of the shaded region?
Thanks in advance!
Mathematics news on Phys.org
I would suggest finding the area of the circular sector \(\displaystyle OAB\) (you know or can find the radius and the subtended angle), then subtract away the area of \(\displaystyle \Delta OAB\).
I notice you have \(\displaystyle \overline{OA}\) marked as 2, but it should be 1, making \(\displaystyle \overline{AB}=\sqrt{3}\).
Thanks for the reply! So would OA be identical to OB, then?
Alright, I managed to answer my own question. OA and OB are identical. But how can I find the radius of the circle? I guess that is basically what the entire issue is, seeing as how I cannot get the radius from the diagram (I think).
Thanks in advance!
The radius is \(\displaystyle 1=\overline{OA}=\overline{OB}\). Any line segment from the center to a point on the circle is a radius.
OK, then. But the height of the triangle AOB is still 1/2, am I correct? I have gotten this:
Area of Circle
A = (pi)(r)^2
= (pi)(1)^2
= (pi) units
Area of Triangle AOB
A = (BxH)/2
= (√3 x 0.5)/2
= (√3)/4 units
So I would subtract the Area of the Triangle AOB from the Area of the Circle, and I would get the shaded area?
Thanks in advance!
You want to subtract the area of the triangle (which you have correctly computed) from the area of the circular sector, not the entire circle. Do you see why?
My apologies, I've never done a question like this before and I don't see anything from my notes or previous questions that resembles something along these lines. So I am going to guess that I have to do this:
> Divide area of entire circle by 2
> Divide segments by 2 both times (because the top right and bottom right segments are broken in half)
> Add together
So, something like this:
Area of entire circle = π units
(The circle has 4 equal segments)
Area of 1 segment = π/4
(2 segments of the same size, so multiply by 2)
Area of both full segments = 0.5π
(For segments that are cut in half, divide π/4 by 2)
Area of half-segment = 1/8π
(Multiply the half-segment by 2 because there are 2 of them)
Area of both half-segments = 0.25π
Add them together = 0.75π
Is this correct?
Using your method, you could get the correct result, but the picture is misleading you with regards to the angle. The angle is actually larger than it is drawn.
The formula for the area $A_S$ of a circular sector is given by:
\(\displaystyle A_S=\frac{1}{2}r^2\theta\)
Now, we already know $r=1$, and we know \(\displaystyle \theta=2x\), and we know:
\(\displaystyle \sin(x)=\frac{\sqrt{3}}{2}\)
So, can you find $x$, then substitute for $r$ and $\theta$ in the above formula for the area of the sector?
OK, so I followed what you said and got this:
A = (0.5)(r)^2(θ)
= (0.5)(1)^2([√3]/2 x 2)
= (√3)/2 units
Is this correct?
No, you are using \(\displaystyle \theta=2\sin(x)\), but what we need is \(\displaystyle \theta=2x\)
If \(\displaystyle \sin(x)=\frac{\sqrt{3}}{2}\) and \(\displaystyle 0<x<\frac{\pi}{2}\) then what is $x$?
FAQ: What is the Area of the Shaded Region in Trigonometry Problem?
What is the difference between area and trigonometry?
Area is a measure of the size of a surface or region, while trigonometry is a branch of mathematics that deals with the relationships between the sides and angles of triangles. In other words, area is a measurement, while trigonometry is a mathematical concept.
How can I use trigonometry to find the area of a triangle?
To find the area of a triangle using trigonometry, you can use the formula A = 1/2 * b * h * sin(theta), where b is the base of the triangle, h is the height, and theta is the angle between the base and the height. You will need to know at least two of these values to find the area.
What is the Pythagorean theorem and how is it used in trigonometry?
The Pythagorean theorem states that in a right triangle, the square of the length of the hypotenuse (the side opposite the right angle) is equal to the sum of the squares of the lengths of the other two sides. This theorem is often used in trigonometry to find missing side lengths or angles of right triangles.
How can I use trigonometry to find the area of a polygon?
To find the area of a polygon using trigonometry, you can divide the polygon into smaller triangles and use the formula A = 1/2 * b * h * sin(theta) for each triangle. Then, you can add up the areas of all the triangles to find the total area of the polygon.
Can trigonometry be used to find the area of a circle?
No, trigonometry cannot be directly used to find the area of a circle. However, you can use trigonometry to find the length of a chord or the measure of a central angle in a circle, which can then be used to find the area of a sector or segment of the circle. The area of the entire circle can then be calculated by adding up the areas of these smaller parts.
