What is the average area of a cut on a sphere by a random plane?
In summary, the question is asking for the average area of a cut on a sphere with a random plane, and the answer can be found by integrating \pi(r^2 - t^2) over the interval t\in[0,r] or t\in[-r,r] and dividing by r or 2r, respectively. The final result is \frac{2 \pi r^2}{3}.
astroboy999
Given a sphere of radius r, what is the average area of a cut given by a random plane meeting the sphere?
I just need someone to check my answer, and maybe suggest an alternative solution if there is a better one. I assumed that the cut is horizontal, then t in my integral below denotes the distance of the plane from the center of the sphere.
The answer is given by the integral
[tex]\frac{1}{r} \int_{0}^{r} 2 \pi (r^2 - t^2) dt[/tex]
and it works out to [tex] \frac{2 \pi r^2}{3} [/tex]
In particular, is there a clever solution that may not use an integral? I also may have made calculation mistakes, so I would be grateful if someone checks the answer for me... thanks!
Where did the initial factor of [tex]2[/tex] in the integral come from? The area of the disc cut by a plane at height [tex]t[/tex] is [tex]\pi(r^2 - t^2)[/tex], and you are averaging this over the interval [tex]t\in[0,r][/tex].
Well, don't I want to average over the interval [-r, r]? But maybe I needed the factor of [tex]\frac{1}{2r}[/tex], instead of [tex]\frac{1}{r}[/tex]. Is that correct?
By symmetry, it doesn't matter -- but you must be consistent. You must either integrate from [tex]-r[/tex] to [tex]r[/tex] and divide by [tex]2r[/tex], or integrate from [tex]0[/tex] to [tex]r[/tex] and divide by [tex]r[/tex]. Either way, the integrand should be [tex]\pi(r^2 - t^2)\,dt[/tex], without a factor of [tex]2[/tex].
FAQ: What is the average area of a cut on a sphere by a random plane?
What is the definition of "average" in a continuous model?
The average in a continuous model refers to the central tendency of a set of data points, which can be represented by the mean, median, or mode. It is a statistical measure that summarizes the data and gives an indication of the typical value.
How is the average calculated in a continuous model?
In a continuous model, the average is calculated by taking the sum of all the data points and dividing it by the total number of data points. This can be expressed as the formula: average = sum of data points / number of data points.
What is the difference between mean, median, and mode in a continuous model?
The mean is the most commonly used measure of average in a continuous model. It is calculated by adding all the data points and dividing by the total number of data points. The median is the middle value of a data set when arranged in numerical order, while the mode is the most frequently occurring value. In a continuous model, the mean is affected by extreme values, while the median and mode are not.
How is the average used in a continuous model?
The average is used in a continuous model to summarize and describe the data. It can help in identifying trends and patterns in the data and making comparisons between different data sets. It is also used to make predictions and draw conclusions about the population from which the data was collected.
What are some limitations of using average in a continuous model?
One limitation of using average in a continuous model is that it does not provide information about the variability or spread of the data. It also assumes that the data is normally distributed, which may not always be the case. Moreover, it can be affected by outliers or extreme values. Therefore, it is important to consider other measures of central tendency and analyze the data as a whole to get a more comprehensive understanding.
