What is the basis for each eigenspace?
  • MHB
  • Thread starter saqifriends
  • Tags
    Basis
In summary, the basis for each eigenspace is a set of linearly independent vectors that span the corresponding eigenspace. To find the basis for an eigenspace, one must first find all the eigenvectors corresponding to a specific eigenvalue and use them to form a basis by checking for linear independence and spanning the space. The basis for an eigenspace can change depending on the chosen eigenvalue, as different eigenvalues may have different corresponding eigenvectors. This basis is important in understanding the structure and behavior of a linear transformation, and the number of vectors in the basis is equal to the dimension of the eigenspace.
saqifriends
saqifriends said:
https://www.physicsforums.com/attachments/215
Hi saqifriends, :)
Find the eigenvalues using the characteristic equation, \(|A-\lambda I|=0\). You will get, \(\lambda=2\pm 3i\). Then for each eigenvalue find the corresponding eigenvectors. The eigenvectors for a given eigenvalue define the eigenspace for that particular eigenvalue. Finally find a basis for each eigenspace.
Some worked examples similar to your problem can be found here. Hope you can continue.
Kind Regards,
Sudharaka.
FAQ: What is the basis for each eigenspace?
The basis for each eigenspace is a set of linearly independent vectors that span the corresponding eigenspace.
How do you find the basis for an eigenspace?
To find the basis for an eigenspace, you first need to find all the eigenvectors corresponding to a specific eigenvalue. Then, you can use these eigenvectors to form a basis for the eigenspace by checking for linear independence and spanning the space.
Can the basis for an eigenspace change?
Yes, the basis for an eigenspace can change depending on the chosen eigenvalue. Different eigenvalues may have different corresponding eigenvectors, thus resulting in a different basis for each eigenspace.
What is the importance of the basis for each eigenspace?
The basis for each eigenspace is important because it helps us understand the structure and behavior of a linear transformation. It also allows us to easily compute the eigenvalues and eigenvectors of a matrix.
How does the dimension of the eigenspace relate to the basis for each eigenspace?
The dimension of an eigenspace is equal to the number of vectors in the basis for that eigenspace. In other words, the basis for each eigenspace forms a basis for the entire eigenspace, and the number of vectors in the basis is the dimension of that eigenspace.
