What is the binding energy of a protium nucleus?
In summary, the binding energy of a protium (hydrogen-1) nucleus is the energy required to bring two nucleons from infinity to a stable state in a nucleus. However, since there is only one nucleon in a protium nucleus, the binding energy for that nucleus is considered to be zero. The binding energy for a quark is far more complicated, as quarks do not exist in isolation and trying to pull them apart will only result in more quarks being created. While single quarks have been detected, they always exist bound to another quark and cannot be detected in isolation. The existence of lone quarks would contradict quantum chromodynamics. Therefore, the concept of binding energy for individual quarks is not applicable.
Pranav Jha
141
what is the binding energy of protium (hydrogen-1) nucleus? As i understand binding energy, it is the energy required to bring two nucleons from infinity to a stable state in a nuclues but if there is only one nuclide in a nucleus how do we determine the binding energy for that nucleus?
is the mass of a proton in a protium nucleus (if there is any difference between free proton and a protium nucleus) the same as that of a "free proton"?
That would be the infamous "self-energy". Interesting.
What is the binding energy of a quark?
sir/madam, i have just started nuclear physics. Your reply only confused me further
It's zero.
Something must be binding the quarks to form the proton (3 quarks inside). So shouldn't there be binding energy?
Of course, but that's not what the question is about. The question is about nuclear binding energy. Since there is only one particle, it's zero.
For quarks, it's far more complicated. If you ask how much energy it takes to disassemble a nucleon, the answer is infinite. Quarks do not exist in isolation, and trying to pull them apart will only result in more quarks being created. If you want to compare the mass of the proton to masses of individual quarks, you run into more problems. What is the mass of the quark? Well, a reasonable answer would be whatever goes into quark's Lagrangian to make all the numbers work. That's called a current mass. But again, mass of the proton is significantly higher than sum of the current masses of constituent quarks. So that doesn't give you anything useful either.
Likes Rongeet Banerjee
A "single quark" in this case means that it exists without it's anti-particle pair. Normally, top quarks are produced via strong interaction. That means that you always find them in t-t-bar pairs. What these researchers have found are top quarks produced by weak interaction. Or alternatively, top quarks destroyed by weak interaction. At any rate, they end up with a top quark without a t-bar pair. However, that quark does not exist in isolation. It exists bound to some other, lighter quark. A lone quark is not a physical particle, as it always exists off the shell, and therefore, cannot be detected. If someone was to detect a lone quark, it'd mean we have to scrap the QCD.
I see. Thanks for the clarification. :)
But how do you put all the electrostatic charges into such a tiny quark against all the electrostatic repulsion in the first place . So there should be some kind of binding energy in the first place, to pack all the charges into this tiny quark ?
FAQ: What is the binding energy of a protium nucleus?
What is binding energy?
Binding energy is the amount of energy required to break apart a nucleus into its constituent parts, namely protons and neutrons.
What is the binding energy of protium?
The binding energy of protium, also known as hydrogen-1 or simply hydrogen, is approximately 2.23 MeV (mega-electron volts).
How is the binding energy of protium calculated?
The binding energy of protium is calculated using the famous equation E=mc^2, where E is the binding energy, m is the mass deficit (difference in mass between the nucleus and its constituent parts), and c is the speed of light.
Why is binding energy important in nuclear physics?
Binding energy is important in nuclear physics because it determines the stability of a nucleus. Nuclei with higher binding energy are more stable, while those with lower binding energy are more prone to decay.
What factors affect the binding energy of protium?
The binding energy of protium is affected by the number of protons and neutrons in the nucleus, as well as the nuclear forces that hold them together. It is also affected by the mass defect, which is the difference in mass between the nucleus and its constituent parts.
