What is the bond order of (Fe2) and (Fe2)+ ?
In summary, the bond order for ## Fe_2 ## is calculated to be 4 based on its electron configuration and the bonding and anti-bonding orbitals in the 3d orbital. The bond order for ## (Fe_2)^+ ## is 4.5, with 10 bonding electrons and 1 anti-bonding electron in the 3d orbital. However, these calculations may not correspond to experimental bond strength due to the LCAO approximation.
CGandC
326
34
Hi ,
I was wondering what is the bond order of ## Fe_2 ## and ## (Fe_2)^+ ## ?
Is the molecule ## Fe_2 ## even able to be covalently bonded? if so , why not?
Bond order = ( # bonding electrons - # antibonding electrons ) /2
From almost writing the complete Molecular orbital electron configuration for ## Fe_2 ## and ## (Fe_2)^+ ## ( I said ' almost ' because I don't know how to write the electronic configuration for the d-bonds ) then I think the bond order for ## Fe_2 ## is 0 and the bond order for ## (Fe_2)^+ ## is 1/2
CGandC said:
Problem Statement: Hi ,
Relevant Equations: Bond order = ( # bonding electrons - # antibonding electrons ) /2
You might need a few more relevant pieces of information than you've given. One, if you have ##N## total atomic orbitals, how many molecular orbitals will you have? Two, it's important to note that the valence electrons of the d-block include ##ns## as well as ##(n-1)d## orbitals. So for iron, you'd need to take into account the ##4s## orbitals in addition to the ##3d## orbitals.
One easy way to approach bond order in the transition metals is to look at the analog in p-block elements. If you can figure out (e.g.,) why N2 has a triple bond, but C2 and O2 only have double bonds, then you should be able to apply the information I gave you above to figure out what the bond order of Fe2 should be.
NB--As the paper from @mjc123 points out, the formal bond order does not always correspond to the experimental bond strength, mainly because the LCAO approximation is just that: an approximation.
Likes dextercioby
Thanks.
I was given the answer by an instructor for what the bond order of ## Fe_2 ## and ## (Fe_2)^+ ## is:
The electron configuration of ## Fe ## is ## (1s)^2 (2s)^2 (2p)^6 (3s)^2 (3p)^6 (4s)^2 (3d)^6 ##
Therefore I have 6 electrons in the last orbital corresponding to the final highest energy level ( the ## 3d ## orbital ) for a single ## Fe ## atom.
Therefore, for ## Fe_2 ## molecule I'll have at total 12 electrons which occupy the final highest energy level ( according to aufbau principle of course ).
Since there is a ## Fe_2 ## molecule , then in the ## 3d ## orbital there two kinds of orbital divisions : bonding orbitals and anti-bonding orbitals.
Since each orbital in the d-orbital can occupy 10 electrons, then according to aufbau principle, there will be 10 electrons that will occupy the bonding orbitals and then there will be 2 electrons that will occupy the anti-bonding orbitals.
Therefore , the bond order for ## Fe_2 ## is: ( 10 - 2)/2 = 4
And for ## (Fe_2)^+ ## there will be 10 electrons that will occupy the bonding orbitals and then there will be 1 electron that will occupy the anti-bonding orbitals ( still talking about the ## 3d ## orbital ) .
Therefore , the bond order for ## (Fe_2)^+ ## is: ( 10 - 1 )/2 = 4.5
CGandC said:
Thanks.
This is the right answer, although I want to point out one thing. As I said previously, both the 4s and 3d orbitals contribute to the valence electron shell. This gives a total of 6 orbitals for each Fe atom. Since the total number of molecular orbitals must equal the total number of atomic orbitals in the system, we have 12 molecular orbitals in all. By symmetry, 6 of these will be bonding and 6 will be antibonding. For Fe2, each Fe has 6 d electrons and 2 s electrons in the valence orbitals, meaning there is a total of 16 electrons to fill the 12 molecular orbitals via the aufbau principle. So all 6 of the bonding orbitals will be filled, and 2 of the antibonding orbitals will be filled, giving an overall bond order of 4. Likewise, removing one electron to get ## (Fe_2)^+ ## will give a bond order of 4.5.
As I said, the answer was right, but the s orbital plays an important role. In fact, it's the whole reason we say species like ##Mo_2## and ##W_2## have a formal sextuple bond. This actually has experimental ramifications. Ignoring the s orbitals leads to the prediction that the formal bond order (and ultimately the strength of the bond) is higher for ##Mn_2##, ##Tc_2##, and ##Re_2## (quintuple bond) than for ##Cr_2##, ##Mo_2##, and ##W_2## (sextuple bond including s orbitals, quadruple bond excluding s orbitals). Experimental measurements show that the latter are the stronger bonds.
One final point: there is reasonable disagreement over whether the 4s orbital really counts as a valence orbital for the first row of transition metals (it definitely does for the second and third rows), as the energy between 4s and 3d orbitals is proportionally larger than 5s/4d and 6s/5d. I will point out that ##Cr_2## has a much stronger bond than ##Mn_2##. But, even that isn't the whole story. The manganese atom has a ground state configuration of ##4s^2 3d^5##, a half-filled d-subshell. The first excited state has a configuration of ##4s^1 3d^6##, but because the ground state is so stable, the excitation energy to this state is quite large (>2eV). But the total bond energy of the ##Cr_2## dimer, for comparison, is only about 1.5eV. So if we expect that the bond energy of ##Mn_2## is comparable, once we factor in the energy required to hybridize electrons in Mn atoms to form the covalent bond, we find that manganese does not form a covalent dimer at all! There simply isn't enough energy available. In fact, that's what we observe experimentally, with ##Mn_2## being a very weakly bound (<0.1eV) van der Waals dimer.
Likes CGandC
Related to What is the bond order of (Fe2) and (Fe2)+ ?
What is the bond order of (Fe2)?
The bond order of (Fe2) is 2. This is because (Fe2) has a total of 8 valence electrons, and it forms 4 bonds with a bond order of 2.
What is the bond order of (Fe2)+?
The bond order of (Fe2)+ is also 2. This is because (Fe2)+ has a total of 7 valence electrons, and it forms 3 bonds with a bond order of 2.
Why does (Fe2)+ have a lower bond order than (Fe2)?
(Fe2)+ has a lower bond order because it has one less valence electron than (Fe2). This means that there are fewer electrons available for bonding, resulting in a lower bond order.
What is the significance of bond order in (Fe2) and (Fe2)+?
Bond order is a measure of the stability of a molecule or ion. A higher bond order indicates a more stable molecule or ion, while a lower bond order indicates a less stable molecule or ion.
How does the bond order of (Fe2) and (Fe2)+ affect their chemical properties?
The higher bond order of (Fe2) makes it more stable and less reactive compared to (Fe2)+. This is because the higher bond order in (Fe2) means that the bonds are stronger, making it harder for the molecule to break apart and react with other substances.
